Fitting TPI to different car what parts do I need?
Old Jul 14, 2005 | 10:51 PM
IroczInOz's Avatar
I am posting this question on behalf of someone. They have a 89 TPI set-up and want to fit it to a car that never came with TPI.
Currently he has a MAF ECM but I said to him I would go with MAP. Saves him money not having to buy the MAF, Relay etc..
If he wanted to go with a MAP set-up what parts are needed for the install like sensors etc...
I can think of the follwoing:
Wirring Harness (730)
ECM 730
Knock Sensor
Memcal
O2 sensor
Water Temp Sender
Map Sensor
TPS
Fuel Pump Relay
MAT sensor
ESC control box is not needed since the MAP knock sensor connects directly to the ECM correct?
If anyone can think of any parts that are needed can you please list them. He is wanting to get this done ASAP.
If people know the part numbers that would be an awesome help too!
Thanks,
Mike
Old Jul 15, 2005 | 01:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i dont believe the 89 TPI setup plenum will work. its not setup for speed density. SD had a slightly different plenum
Old Jul 15, 2005 | 06:45 AM
IroczInOz's Avatar
It will work as my 86 TPI works with MAP. The plenum has nothing to do with it.
I had a read of the technical articles well if all that is needed is listed there then there is not that much.
Old Jul 15, 2005 | 10:07 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
The water temp sender is what sends the temp reading to the dash, not the ecm. If you order a part by that name, you will get the wrong item. What you need is called the CTS sensor.
Yes, the esc circuitry is no longer an external module on MAP setups, but is located inside the memcal.
You need to make sure that you run the correct prom and knock sensor for a 90-92 TPI setup, specific to the engine size.
The only sensors from a MAF setup that are different for MAP are the following: knock, and MAP. All the others can be reused on the MAP setup.
Old Jul 15, 2005 | 08:34 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Possibly and EGR.
Possibly a throttle cable depending on what you have on the car now.
Old Jul 15, 2005 | 10:55 PM
IroczInOz's Avatar
I would have thought the EGR would be already on the plenum as it is mounted underneath it.
Thanks for the input guys. Yeah I think he might need specific throttle cable attachments. I am not sure what transmission he will be running but I think it might be the T400 so that should not be any problen either as it does not have OD.
I suggest him to go the MAP router probably end up being cheaper and less expensive to replace a MAP sensor then a MAF.
Thanks once again!
Old Jul 15, 2005 | 10:57 PM
IroczInOz's Avatar
Oh does anyone know off the top of their head what all sensors are needed for TPI? A list would be good just in case I did not miss anything.
Old Jul 15, 2005 | 11:14 PM
Car: 1989 GTA
Engine: 369 TPI
The style of EGR was changed in 1990 when they went to speed density. I don't know enough about what you have to know if it will work properly. Just a heads up.
On my 1989 with MAF I'm considering going to SD. The EGR may well be an item I will have to change out. Going to give the existing one a go and see if it will work. Allen
Old Jul 15, 2005 | 11:17 PM
IroczInOz's Avatar
You should be fine as my 86 EGR works fine. In the end of it all though It is disabled as I read about numerous posts about the EGR and what the verdict was if you don't spend 90% on the hwy then it hs no real advantage and possibly a disadvantage. So I disabled it anyway.
Old Jul 16, 2005 | 01:32 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
VSS is the only 1 you left out of your list at the top.
if he goes with electric fans, the relays & fan switch for them.
Old Jul 16, 2005 | 04:53 AM
IroczInOz's Avatar
Would he need a VSS if he is not going to use the stock gauges? Or is the VSS for the ECM to know what speed the car is at?
Old Jul 17, 2005 | 01:30 AM
DENN_SHAH's Avatar
he may not need it, but he may well have a problem with dying or surging when coming to a stop without it.
i did have some problems with both without the ECM seeing the VSS signal on my car.
also without it, it will keep kicking the check ehgine light on.
VSS may also be needed for the EGR to work properly.
i would also recommend hooking up a park/neutral switch if he uses an auto trans along with a A/C input if he is going to run A/C.
Old Jul 18, 2005 | 10:54 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Read through this for the Speed Density sensors:
http://tpiparts.net/90_92_speed_density_sensors/
Vss is at the bottom, and it affects alot more things than what has been mentioned so far.
Old Jul 18, 2005 | 10:34 PM
IroczInOz's Avatar
Awesome thanks for that link!
Yeah looks like the VSS is critical no probs great help guys!
Old Jul 21, 2005 | 10:53 PM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
my advice to him would be to buy an aftermarket harness and call it a day.. i fought with trying to use a stock harness in my 79 malibu for over a week, and it still dont run right. Im going to just fork over the dough so i can get it straightend out...
Old Jul 22, 2005 | 02:39 AM
DENN_SHAH's Avatar
using the stock harness wasn't a big deal for me, i spent a few hours laying it out labeling the wires for the inside the car & making some repairs. once i got the motor in, it only took me about 5 or 6 hours to get it up & running, that includes enlarging the hole for the computer harness in the firewall & getting it sealed up.
i think opening up the harness & inspecting every wire end to end & then repairing anything i thought may cause problems saved me a lot of headaches.
Wade787b
Sep 29, 2015 01:15 PM
86IROC112
Aug 17, 2015 02:00 PM
1nastygta
Aug 8, 2015 07:38 PM
rh76camaro
Exterior Parts for Sale
Aug 6, 2015 08:57 AM
3rdgenparts
Aug 5, 2015 11:57 PM
