stock FPR diaphragm
Old Jul 19, 2005 | 04:12 AM
pawcio's Avatar
Car: GTA 89
Transmission: TH700
Axle/Gears: BW 9 bolt
stock FPR diaphragm
is any way to replace it ?
thanks
Old Jul 19, 2005 | 11:43 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Yes, I believe that it can be replaced. The spring/diaphragm portion of the regulator can be bought at auto parts stores. Look for a GP Sorenson 800122.
Old Jul 19, 2005 | 03:32 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Believe it or not that piece's spring is a hair longer then the stock AC Delco Unit. When I installed the GP one it raised my pressure 4 lbs.
Old Jul 20, 2005 | 01:16 PM
Jade Grey's Avatar
Engine: 305TPI
I wonder if the Niehoff Ignition 21720 version of the same part is any better at $42 each?
Old Jul 22, 2005 | 05:39 AM
pawcio's Avatar
Car: GTA 89
Transmission: TH700
uhh ok everything allright
2 days ago when I assembling a home-made AFPR ;-) I broke that tiny center shaft....horror
I fabricate a new shaft and press into the spring
Azrael91966669
25
Jun 20, 2017 04:04 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
Genopsyde
Oct 7, 2015 08:35 PM
86IROC112
Aug 17, 2015 02:00 PM
wayshegoes
Aug 17, 2015 12:00 PM
