254rwhp 305ci
Old Jul 15, 2005 | 10:34 PM
turbobike's Avatar
Car: 87 WS6 Firebird
254rwhp 305ci
For any 305ci fans here is a dyno run of my 87 305ci W6
pocket ported factory heads, 2030 Compucam, 1.6 roller rockers, all free mods, Edelbrock shorties and 3'' exhaust, Ed M mail order prom. Accel coil
Old Jul 15, 2005 | 10:43 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Impressive for a mail order chipped 305.
Good job
Old Jul 15, 2005 | 11:19 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have to agree. Those are very good results. Heck your 305 makes more peak torque than my 350. Allen
Old Jul 16, 2005 | 01:32 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Re: 254rwhp 305ci
STICK OR AUTO ?
Old Jul 16, 2005 | 06:01 AM
turbobike's Avatar
Re: Re: 254rwhp 305ci
Originally posted by Jetmeck
STICK OR AUTO ?
5-speed...
Engine likes 13.1-2 Air/fuel ratio, lost HP if I richened it up more. Peak torque surprised me, sort of funny watching a SBC run out of breath at 4400rpm though.....
Old Jul 16, 2005 | 07:20 AM
stroked1990RS's Avatar
Car: 1988 formula 350
Axle/Gears: 373
that is funny huh only 4400 ? when u drive her on the srteet do u feel it stop pulling after 4400 rpm ? i had a lil 305 and it pulled ok till about 5500 .
Old Jul 16, 2005 | 08:23 AM
Scheister's Avatar
Car: 85 IROC
cool results! im actually in the process of putting my motor back together and im ganna have a similar setup.
Old Jul 16, 2005 | 08:37 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
whos prom?
Old Jul 16, 2005 | 10:34 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
My 305/T5 Formula dies around 4600 RPM.... sounds like you had either strong runner (oddly strong) or the "Seat of your pants" is broken
Old Jul 16, 2005 | 10:42 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
with a cam and bigger aftermarket TPI stuff, a 305 should be well fed till 5000-5500rpms as most 350's die at 4500-5000 on same stuff.
but nice numbers nonetheless
Old Jul 16, 2005 | 11:02 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Mine pulls over 5700 rpm's
Old Jul 16, 2005 | 12:24 PM
Jetmeck's Avatar
Re: Re: Re: 254rwhp 305ci
5-speed...
HOW HP DIFFERENCE WOULD AN AUTO MAKE ? ANY IDEA ? THX.
bILL e.
Old Jul 16, 2005 | 09:46 PM
Car: 1989 GTA
Engine: 369 TPI
Maybe 5% less RWHP. Allen
Old Jul 16, 2005 | 10:08 PM
Axle/Gears: 373
about my 305 that pulled to 5500 it had a after market intake carb and headrs. cam was stock i think . it was a 5 speed car with 373 gears . i had no problems going to 5500 rpm .
Old Jul 16, 2005 | 10:13 PM
turbobike's Avatar
Originally posted by IROCZ4BD3
whos prom?
Ed Maher..moderator/contributor to TGO
It definetly quits pullin after 4500, by 4800 it feels dead..
But that is the trade mark TPI system. It runs 13.80's at 100-101mph, 2.15 60".... maybe time to install that Garrett T4 turbo kit I have under the workbench...
Old Jul 16, 2005 | 10:37 PM
Car: 1989 GTA
Engine: 369 TPI
I have mine shifting at 6000rpm on the 1-2 shift and 5600rpm on the 2-3 shift. Pulls hard all the way. This is with TPI. Allen
Old Jul 17, 2005 | 09:18 AM
GOY's Avatar
GOY
Okay, it seems that everyone with a 305 is saying they pull way past 4800 RPM, but it also seems that everyone that says that does not have stock equipment.
I thought we were talking about stock runners/base heads, etc. With that, my stocker (w/ headers/exhaust) only pulls to about 4600 RPM, and dies a quick death.
Old Jul 17, 2005 | 01:04 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Heck ....me too I have 251 rwhp and 318 rwtq ....untuned and rich but sheeeeze WTG man
Old Jul 17, 2005 | 03:24 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Ed burned my chip too.
Old Jul 18, 2005 | 11:23 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
IROCZ4BD3, do you have a dyno sheet to prove that your engine pulls to 5700 rpm? I would like to see that before I put stock in your claim.
with the automatic and the STOCK chip mine put down the numbers in my sig. I would say I would match you on power with the 5speed thats in the car now, but how the heck are you makin 350rwtq!?
Old Jul 18, 2005 | 12:08 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I guess I am glad I don't have TPI. Your torque curve is alot more peaked than mine, Tuned Port for ya. My torque curve holds up longer on both ends. Mine is nearly flat from where it registerd 325 ft/lbs from 2,300 all the way to 4,000 or so. I peaked at 340 ft/lbs at a low 2,800. My 305 pulls to 5,500 and it has all stock equipment except for the headers and tuning. Stock 305HO/350TBI cam, pocket ported & gasket matched 081 heads, stock flattop pistons with 4 valve reliefs, stock forged crank, stock X rods, gasket matched stock throttle body intake, stock TBI, custom chip. I made 245 RWHP @ 4,800 with a TBI engine.
I now have an edelbrock performer bored to 2", a 454 TBI, and 350 injectors. That has awoken this engine on the high end above 4,400 or so, with no apparent loss in low speed torque.
Old Jul 18, 2005 | 06:17 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Never gave any torque numbers that I see in any of my posts.No dyno sheet either but after 3 yrs of taking it to the racetrack 3 times a week,I systematically figured out where to shift 1 to 2 then used the same system for the 2 to 3 shift.My porting was NOT done with a dremel but by someone who had access to a highly tech machine shop.The openings on the plenum are siamesed together as are the SLP runners.The base is ported all the way thru each runner and when installed you could actually feel how much lighter it was as compared to the stock one that we took off.I had a CUSTOM cam ground by Comp Cams to fully use the ported intake.I purchased a set of ported TPI heads off a friend then had them sent to my machine shop for screw in studs,replace/recut the seat on the valves,clean up the porting etc.But if you still don't believe me this sat it willbe at the Nat'l gathering racing at my track Cecil County so you can see for yourself.BTW I cut 1.8 60'
Old Jul 18, 2005 | 07:59 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
BTW I cut 1.8 60'
Not on street tires .
Old Jul 18, 2005 | 08:49 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
1.9's on Pep Boys Futura Ulta Z's & got plenty of timeslips to back it up.Was only able to run 14.0's with the street tires and only picked up a tenth w/ the DR's.
Old Jul 19, 2005 | 11:33 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
IROCZ4BD3, I was not confronting you about torque. I was asking turbobike how the heck he got that much torque. I was confronting you about your claim of 5700 rpm, which if you have your intake hogged out that much maybe your engine does pull that high, I did not know you had siamesed all that stuff, now I do. I do have to wonder though, why are you running the same times as me? with my automatic i went a 13.9 with a 1.98 60ft at only 96.5 mph. Now with the 5speed and a horrible 2.2 60ft i am trapping 98.5mph. my intake is just a lightly ported and gasket matched stocker. some interesting numbers in this post......
Old Jul 19, 2005 | 11:36 AM
GOY's Avatar
GOY
You picked up 2 MPH by swapping to a 5spd? Sweet! Sorry - I realize I'm off the beating path here... just acknowledging that.
Old Jul 19, 2005 | 05:53 PM
turbobike's Avatar
1Meanz...the torque...surprised me too...
I think most people put to much cam into thier car for a TPI, the Comp 2030 cam is all low and mid range specific. Thats why the hp drops hard after 4400, though. I did a couple tricks from David Vizard books, roller rockers, 30 degree angle valve cuts, really tight on the lifter nut trick and on the leaner side of the air/fuel ratio.
Old Jul 20, 2005 | 12:13 AM
GOY's Avatar
GOY
I'm like the post ***** of this thread, but can you explain what that is exactly, and what's it's purpose is?
Old Jul 20, 2005 | 05:57 AM
turbobike's Avatar
Goy...on page 105 of Vizards book "Smallblocks on a Budget" he explains that taking up all the excess play in the lifter gives the engine more usable cam lift and duration, it also reduces valve bounce and lifter leakage. He goes through a series of steps on how to do it., I picked up a consistant 1mph in 1/4mile..about 15hp..he claims 20hp... I guess allot of little things add up!
Old Aug 18, 2005 | 08:53 PM
85rocker's Avatar
... I was confronting you about your claim of 5700 rpm, which if you have your intake hogged out that much maybe your engine does pull that high......
I had a '91 Formula LB9 dual cats pulleys, Jacobs, SLP, 1.6 rockers and a flowmaster. It pulled 5800rpms all the time no sweat, was the most fun in 3rd gear (T5).
Old Aug 19, 2005 | 02:06 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
85rocker your car does not pull to 5800rpm usless you have a miniram or a super ram. LTR setups do not pull that high period.
Old Aug 19, 2005 | 03:49 PM
GOY's Avatar
GOY
It might make a lot of noise and rev up to there, but it's not "Pulling" anything besides a lot of gas out of your tank at that speed.
Old Aug 20, 2005 | 09:53 AM
85rocker's Avatar
agreed
should have said 'makes' or 'does' or 'is capable of' 5800rpms using 'pull' was a poor choice of words.
Linson
Nov 12, 2015 08:09 PM
scotrans am
Sep 5, 2015 04:26 AM
BahamutRS
Jun 6, 2001 07:00 PM
radiaki
Carburetors
Sep 23, 2000 06:05 PM
radiaki
Sep 12, 2000 12:40 PM
