Make my 305ci TBI do 12's and win a dollar! =D
I've got a 1992 Camaro RS, 305ci TBI...now....I was going to do som performance mods within the next month, which include a SLP cold air induction kit, Flowmaster cat-back exhaust, 125 HP NOS kit, TBI spacer, MSD 6A ignition, MSD Timing Asjustor, Dynomax headers, Edelbrock hi-flow TBI, Hypertech Performance chip. What else can I do to make this thing break into 12's? Or, might that all do it? Keep in mind this is an automatic. Thanks in advance :P
Car: RS
Transmission: 4L60
are you going to be able to get this power to the ground?. the mods sound great to me.
late model 91 rs
fully loaded t-tops
red leather
paint- gm red and yellow blend (light red)
custom pink rims
305 tbi 14"x3" O.E,
computer chip, accel super stock plug wires
MTX sub and amp (very loud)
vic_v8@yahoo.com
late model 91 rs
fully loaded t-tops
red leather
custom pink rims
305 tbi 14"x3" O.E,
vic_v8@yahoo.com
Car: 91 Red Sled
You'll need:
Lower control arms with relocation brackets if you lower and use slicks.
Good gear ratio, at least 3.42 and posi unit.
A torque arm would also help you plant the power. The key to a 12 second 1/4 mile isn't all about power, it's more about the 60' than anything. You'll want to hook and rip out of the hole, best way to do that is to get the suspension, tranny, gears, posi, and lighten up the car.
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i like the mods list but i also agree with the facts about upgrading the rest of the drivetrain as well to handle all that power. espically rear end and lca's. until the power you make hits the ground your not goin anywhere.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear
91 camaro RS
- 305 TBI
I agree with improving the drivetrain. You can say goodbye to that stock tranny if you plant enough power to run 12's. atleast put a stall converter and a shift kit in the tranny so you can get a few fast runs out of it before it blows.
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLp siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73
Modded 700-R4, 2800 stall converter
NO recent time slips.
*1989 RS
*355 CID
*Richmond 3.73
the hook will be key. from the way it sounds you will have the power to get hte mph you need to run a 12, but you won't get much of it to the ground.
figure you need about a 1.75-1.79 60ft to get it done and 103-107 mph through the traps. you can get mph anywhere you want. the best 60ft i have ever seen a peg leg do was like 1.95.
you need suspension in your life, even if you just go to a salvage yard and pick up a posi rear witht he same ratio it would help a lot.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
lata
tim
14.209@95.46mph
Best 60' 1.917
Car: 92 Camaro RS
Engine: 305 TBI
I also agree that you will need to get an all new heavy duty drivetrain, a racing duty transmission, torque converter, drive shaft, 12 bolt posi rearend, boxed or new tube lower control arms, torque arm and slicks will be needed to run 12's, the stock parts will be toast after a few 125 HP hits of NOS. And don't forget frame connectors to keep the body from twisting into a pretzel.
92 Camaro RS 5.0 5-Speed
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
3.08 Posi-trac
Crane cam
HyperTech Chip
I am assuming you will be spending about $1200-$1500 on these mods? If this is so why spend all that money and still have only around 250hp? i just bulit a full roller 355ci sbc and I did it for less than $1500 and I took it to Kippley racing engine's and they dyno'd it at exactly 434hp and 398ft/tq!!! I just took it to the union the other weekend and with my bfg drag radials i ran a 11.56@109.8 in my 86z28 with no sub frames or anything or that sorts!!!!
Car: 92 Camaro RS
Engine: 305 TBI
<font face="Verdana, Arial" size="2">Originally posted by STUB25:
I just took it to the union the other weekend and with my bfg drag radials i ran a 11.56@109.8 in my 86z28 with no sub frames or anything or that sorts!!!!</font>
3.08 Posi-trac
Crane cam
HyperTech Chip
[This message has been edited by DartByU (edited June 03, 2001).]
I'm going to have to settle for 13's. The car is in excellent condition but already has 80K miles on it, and I'm putting this stuff in for fun...I don't want to do a differential job, and I'm not putting slicks on it; I don't have THAT much money and it's a daily drive vehicle, so...
Yeah, I think I'll set the NOS kit to 100 HP and do the other mods...then I'll get one of those MSD RPM switches so it shuts the NO2 off when I switch gears, this way everything will last longer. :P
I guess...13's will be fine. Then I'll buy myself a 4th gen SS. =D
Linson
Aug 21, 2015 02:12 PM
92camaroJoe
Aug 13, 2015 06:07 AM
