Miss in drive but not in park
If my car is in park/N it runs great and it revs well but when I put it in drive and start going down the road there is a miss. It isn’t constant but it happens every couple of secants or so. I have no idea what is causing it because it doesn’t happen in park/N. It is happens most at about 1700 rpm and up not so much at idle. Any ideas what it could be would help.
350 tpi SD not maf
new distributor and coil
350 tpi SD not maf
Car: 1987 GTA
Transmission: 4L60e
some misses only show up when you put a load on the car.
Have you inspected your spark plug wires for burns or cracks? Also, have you inspected your plugs?
I had a fairly decent miss a while back and it turned out one of my plugs was just gapped too small. I must have dropped it on the floor while putting it in.
Put new spark plugs in and it still runs like crap. And i didn't have any burnt wires untill after i put the i put the wires back on. and now it runs like crap and i have to replace one of my wires.
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
my friend had a miss and a bent valve was causing it. the car ran great but it had a miss to it might wanna check that out
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
