wtf is this? image inside..
Old Jul 24, 2005 | 03:35 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I was looking at a car on ebay when I seen this picture. What is that between the throttle body and tpi? From the description it may be a "Helix Power Tower spacer"
What advantages does this add/have? Almost looks like a NOS cheater plate but its obviously not... 1" spacer to help the air atomize the fuel?? I dunno.., enlighten me.
Thanks.
Old Jul 24, 2005 | 04:40 AM
crazycrocket's Avatar
Car: 1985 camaro
It won't be anything to help fuel atomization unless it has twists or bumps, or something that causes an air distubrance. It does look like a spacer like there would be on a carberated engine, however as I said above it needs bumps or twists to help in any way with fuel atomization since the fuel is only injected from the injectors near the vavles.
It may be an old gimick or product that was removed from the market because it was found not to be effective
Old Jul 24, 2005 | 09:38 AM
Vader's Avatar
The toasted little puppy may be right. It looks just like one of those devices designed primarily to help evaporate cash from your wallet.
Old Jul 24, 2005 | 09:47 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Its one of those cheesie vortec spacers "designed to swirl the incoming air". Works great until the air has to make a sharp right or left turn to enter the runners at which case your swirling pretty much stops! Nice and shiny though!
Old Jul 24, 2005 | 12:25 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Drill and tap it and put a nozzle in it and then it will be worth something.
Old Jul 24, 2005 | 12:38 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
well.... do your own test... pull it off.. and see how the throttle response and drivability is... then put it back on and see what changed.. if anything
Old Jul 24, 2005 | 01:25 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
???? What would be the point of making the air more turbulent if you have a air foil to smooth out the air right before that?? Makes NO sense to me.
Old Jul 24, 2005 | 01:39 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
The only thing it does is to slightly increase plenum volume.
Its completely useless unless you have a purple air filter....
Old Jul 24, 2005 | 03:05 PM
Rob Wade's Avatar
I think the idea is to create a swirl for more complete combustion. If you think about it there isn't a snowball's chance in hell you will still have any "swirl" (if there was any to start) by the time you reach the combustion chamber. Kind of like the tornado will improve your fuel economy!
Old Jul 24, 2005 | 03:26 PM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
There's one on ebay
http://cgi.ebay.com/ebaymotors/Tuned...QQcmdZViewItem
Old Jul 24, 2005 | 08:18 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
It is a Helix Power Tower, and it does exactly what it's supposed to do: separate you from your money. In theory, it funnels and swirls the incoming air and gives you a better air/fuel mix. Nothing but snake oil.
Linson
Oct 24, 2025 02:00 PM
sammy52401
Nov 11, 2015 07:20 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Gordonr1973
Sep 29, 2015 11:59 AM
