Eng just died.
Old Jul 25, 2005 | 04:22 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Eng just died.
Cruising the other night and had the eng just up and die 4 times. 2 times i rolled to a stop and started it and 2 times I put it in N and started it while rolling. 99% sure it is fuel or spark (what else is there?), my question is if the fuel pump cut out would the eng up and die or would it sputter first then die? My first guess is the ign module but wanted input on possible fuel pressure lose before I start diagnosing it.
89 Formula, HSR
Old Jul 25, 2005 | 04:31 PM
Guest
Guest
Posts: n/a
If you were to suddenly lose fuel pressure, its gonna stop running. Have a fuel pressure gauge? Might be the time to get one.
Old Jul 25, 2005 | 04:49 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
It fuel pressure. Check the fuel filter
Old Jul 26, 2005 | 09:59 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
I do have a FP gauge but it is under the hood, did not think about looking at it at the time, was just happy it fired up each time. Will have to see if I can get it die again and check the pressure. Glogged filter is def a possibility, will change to be safe.
Old Jul 26, 2005 | 11:20 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Start the car and have someone watch the pressure gauge while you give it gas. If the pressure drops or isn't consistent, then you know your problem. The car doesn't have to be under load if you are losing enough pressure.
Anyway, I also vote fuel over spark. Check it all out.
Old Sep 2, 2005 | 05:04 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Not fuel pressure, I was able to move my FP gauge where I could see it while driving and it did not drop at all when the eng died. My next thought is the ign module, any other suggestions?
Old Sep 2, 2005 | 10:04 AM
88TAJeff's Avatar
Car: 88 T/A
Do you have a timing light? When it dies, you could hook up the timing light to see if there's spark.
It wouldn't be unusual to be the module, I've had a couple go on me.
Old Sep 2, 2005 | 11:28 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
It is intermittent and has only happened when driving, I have a spare module (that I should keep in the car) that I will try. Intermittent problems suck.
Old Sep 2, 2005 | 09:12 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
"Intermittent problems suck."
You can say that again, my 85 TPI has a few of em that I don't feel like figuring out right now. I work on cars everyday at work, and have 0 motivation to work on my own, lol. These cars can be a pain in the butt for some reason.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
roysatikas
Sep 22, 2015 08:15 PM
perZ
Aug 21, 2015 05:51 PM
