TBI and TPI distributor interchange?
Old Jul 30, 2005 | 01:21 PM
NoCal91Convert's Avatar
Car: 1991 Z28 Convertible
Transmission: 5 Speed
In a roller motor (305) is a TPI and TBI distributor interchangeable? (1989)
Old Jul 30, 2005 | 02:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Longs as years are '87-up (divorced coil)...
I/e the dizzy in my 91RS is the same as in my '89IROC
Old Jul 30, 2005 | 07:26 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Re: TBI and TPI distributor interchange?
It was a major problem on my swapover. I have a1993 Caprice wagon that I'm swapping from TBI to TPI. The base circle at the top of the shaft was a different diameter. The old shaft from the 93 was a larger diameter base than the TPI manifold hole was. I had to hog out the hole larger.
It was not fun. The shaft would not engage the oil pump, and it took me a while to realize why, that the distributor was not dropping down all the way into the manifold hole. It had nothing to do with the Oil pump.
The alternative would have been getting a new Distribuotor.
Old Jul 30, 2005 | 11:26 PM
I was told the newer caprice had a different size hole, I'm not sure that is a tbi/tpi difference, rather a difference between models and more specifically, years. I believe the diameter will be the same if it was before 1992, or so I've been told.
Old Jul 31, 2005 | 02:07 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Basically what lakeeffect said and what u were told norcal.
Think it is 93-95 caprice TBI are different.
Long as u go from say small cap to small cap from 87-92 range u should be fine.
I am not quite sure if anything else used the larger small cap base or it was just common to the caprice or all later TBI setups.
U can easily see it if u walk thru a junkyard and look at them or have one of each to compare.
later
Jeremy
Old Jul 31, 2005 | 07:46 AM
lakeffect2's Avatar
So the point is... Measure what you have, and make sure the sixes both match up. Then at least you'll be ok on that portion of things...
Old Jul 31, 2005 | 03:19 PM
Yep, measure twice and cut.... well you know. My biggest concern was that the distributor was from a roller motor as I believe the gears are made differently..... one is more likely to do damage to the cam gear.
Thanks so much for your reply. You really can learn a bunch if you just read and listen. I'm hoping this distributor is the reason I'm not getting spark as I have replaced both the coil and the ICM.
Ken
Old Jul 31, 2005 | 07:59 PM
Damon's Avatar
GM cams (roller or flat tappet) all used the same cam gear and therefore the same distributor gear. It's aftermarket roller cams that might need a softer distributor gear to keep from chewing them up.
Old Jul 31, 2005 | 11:41 PM
That puts my mind to rest. Thanks for the information.
junkcltr
Aug 2, 2019 11:12 PM
pimp2303
Jul 27, 2017 02:03 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
tero
Aug 6, 2015 06:34 PM
