TPI Confusion
Old Aug 5, 2005 | 11:44 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
TPI Confusion
I have a friend with a 1990 IROC with a Tuned Port Speed Density 350. What has always confused me about his car is that it has an air pump dumping oxygen into the header tubes. My confusion is that if an oxygen sensor makes adjustments to the air/fuel ratio, how can this be done accurately if you are artifically dumping oxygen into the exhaust, not really giving the oxy sensor a true sample of what's happening in the motor. Can someone explain? Thanks!!
Old Aug 5, 2005 | 11:50 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
there is an offset that gets subtracted from the target O2 sensor reading when the air pump dumps air into the exhaust upstream of the sensor.
Old Aug 5, 2005 | 12:03 PM
wesilva's Avatar
Transmission: 200R4
Thanks 88305. So rumours of gaining a little horspower by gutting the air pump would actually screw things up unless you recalibrated the ECM...correct?
Old Aug 5, 2005 | 12:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Once closed loop hits all the air is diverted to the cat anyways
Old Aug 5, 2005 | 03:03 PM
wesilva's Avatar
Transmission: 200R4
At what point does the system go into "closed loop"?
Old Aug 5, 2005 | 03:48 PM
AlexJH's Avatar
Engine: 5.7L V8
It depends... but when I'm datalogging it usually takes about a minute if I'm driving, 2 mins at idle.
Old Aug 5, 2005 | 05:42 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
While the air is being diverted to the headers, the engine is ignoring the O2 reading, as it is in open loop.
While the ecm is listening to the input from the oxygen sensor, air is being diverted to the cat.
Old Aug 6, 2005 | 07:54 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
The upstream air stokes the fire above the O2 sensor to heat it up to force closed loop sooner, that is the ONLY reason for the upstream A.I.R. (Air Injection Reaction in case you ever wondered why it's an A.I.R. pump and not an air pump). With the advent of heated O2 sensors, the upstream air was no longer required.
Once switched to downstream, the free oxygen in the air is used in the back half of the converter to combine unconsumed fuel (HC) with Oxygen (O2) to form H2O (water) and CO2. That is why we see steam and water dripping from the tailpipe of late model engines.
Sad thing is, because of stupid EPA regulations; even if you install a heated O2 sensor which is quicker and cleaner, you still can't remove the upstream A.I.R. because it came that way. So even though technology has improved, the stupid EPA won't let you update.
Old Aug 8, 2005 | 09:01 AM
wesilva's Avatar
Transmission: 200R4
Thanks for the help, fellas. You set a fuel injection newbie straight.
RazorN8
Jan 7, 2022 11:44 AM
Cornholio7979
Sep 20, 2018 02:31 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
