92 trans am keeps stalling out!!!!
Old Aug 14, 2005 | 11:32 AM
bossbirdta's Avatar
Car: 92 t/a convert.
Transmission: 5 spd.
good day, need a bit of help here. got a 92 t/a lb9-tpi 5 spd. its a 50,000 mile car. the prob. is after it comes up to temp. with like 5-10 miles, when you pull to a light or sign, it idols for a few seconds then stalls out. from there it only gets worse, and every time is a lil bit harder to start. when i read it with a code reader, it comes back clean, " no trouble codes". does anyone here have an idea what to look for to help resolve this?...... i did just put on a new gm tps thinking it might be it, but no luck there. all help is appreciated!!!!!!
Old Aug 14, 2005 | 08:41 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Take the vacuum source off your egr valve, You can do it at the bottom of the throttle body. Just make sure to plug the hole ( on the throttle body ). If that cures it, you need a new egr valve as the spring is wore out.
Old Aug 15, 2005 | 09:41 PM
bossbirdta's Avatar
hey gmgod, thanks for the tip. i'll try it asap and let ya know.....
jklein337
Sep 19, 2018 06:23 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Bryan F
Aug 18, 2015 02:28 PM
Jake_92RS
Aug 17, 2015 09:42 AM
TreDeClaw
Aug 14, 2015 06:58 PM
