Map Voltage not making sense
Old Aug 25, 2005 | 05:43 PM
tpiten's Avatar
Car: 1994 s-10 with a TPI 5SPD
Transmission: Muncie 5 SPD
I got a s-10 with a 350 TPI. I got it hooked up to a snapon scan tool. The readings on the MAP at idle are 22HG.....3.5 volts. According to some graphs i seen those numbers dont line up??? Ive done searches and found that my wiring is correct Can Anyone help me?
Old Aug 25, 2005 | 10:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ya, idle should be lower voltage..around 1-1.2v
Do you have the correct MAP?
Old Aug 25, 2005 | 10:48 PM
tpiten's Avatar
Well I tried 3 different ones ...nothing. But on a gragh i read around here somewhere 22hg does not equal 3.2volts. If I am not mistakin isnt 22hg pretty good vacuum?
Old Aug 25, 2005 | 10:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yes, very good for idle...you sure you have the correct MAP sensor for a 90-92 TPI F-body, not just one you think will work?
Old Aug 26, 2005 | 06:27 PM
tpiten's Avatar
well i thought a map sensor was a map sensor unless it was for a turbo?
Does it have to be just a 90-92 F-body TPI. I'm sure one of them is from a 89 chev van TBI.
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
86IROC112
Aug 17, 2015 07:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
