fumes and smoke question
Old Sep 6, 2005 | 02:59 PM
'87Phoenix's Avatar
Car: 1987 Pontiac Trans Am
Transmission: Turbo 350
I drive an '87 t/a w/a 350 TPI and it has recently been idling a little sloppy and is pouring smoke from excess fuel. i'm also getting a negative feedback response from my accelerator (kinda deccelerating). The one day I drove it, this is what happened: drove (fine)> parked(1 hour)> drove(sloppy)> parked(30sec)> drove(fine)> parked(1 hour)> drove(sloppy)! I was thinking O2 sensor or clogged cat. any answers are much appreciated.
Old Sep 7, 2005 | 01:06 PM
'87Phoenix's Avatar
smoke and fumes gone but..
that issue aside, I'm still having an issue with the acceleration (in this case, decceleration). TPS? IACV? please help.
Old Sep 7, 2005 | 02:52 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
you have a check engine light on? you might need to put a scanner on it.
Sounds like you might have some leaking injectors, if so, put a fuel presures tester on it.
chazman
Aug 28, 2018 03:25 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
chazman
Aug 22, 2015 02:01 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
