305 SD TPI heads and TPI on a 350 block?
Old Sep 6, 2005 | 09:25 PM
drptop70ss's Avatar
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
With your guys help I now know I can put a 90-92 TPI setup and heads on a 70s block..which now has me thinking. I have 3 TPI 305 engines, 2 SD and 1 MAF. If I were to put the 305 heads and TPI on a 350 block what would I need to make it work? I figure I would need the larger 22# injectors, but what else? Could I use my orignal 305 computer and memcal and just get a stock chip burned for a 350 TPI car? I have a few spare 350s and am thinking I should ditch the 305s.
Old Sep 7, 2005 | 12:42 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
You can reuse the computer, you would just need a 350 prom. You will need either 22 lb injectors, or set the injector size in the prom to 19 and run the 305 injectors. You will need to change the knock sensor as well.
Thats for Speed Density. If you are going to go use the MAF setup you have lying around, all the above applies, plus you need to get the proper ESC.
Old Sep 7, 2005 | 06:26 PM
drptop70ss's Avatar
Car: way too many
wow that is not too bad at all, thanks for the help! I will have to have someone burn me some stock 350 chips.
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
BBSDesigns
Aug 11, 2015 07:39 PM
