new engine-comp cam
Car: 1989 IROC Z
Engine: 5.7
new engine-comp cam
First, I am completely new to forums so forgive me for any mistakes.
Now to my problem, I bought myself a 89 IROC with a bad engine. I rebuilt the engine myself .040 over with flat top pistons, stock heads, resurfaced and vj. I believe my problem may lie in my cam selection. I got a comp cam xr270hr-10. It has gross valve lift I.495/E.502 with duration @ .006 being 270/276. It has 110 deg of lobe seperation. I installed my engine and set the base timeing at 6 before and it doesn't want to run right. The idle goes from around 700 upto 1500, back and forth constantly. I tried adjusting idle, but to no avail. Do I need to reprogram my computer for this cam to work or could my problem be else where? I am getting no check engine lights.
I hope this isn't listed somewhere else, and I am ignored. Like I said, I am new to this. I tried looking around to see if anyone had listed a similar problem, but did not see one.
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
Probably need to reprogram.
Mine did the same thing, and it was it was pig-rich at idle. I adjusted the VE table to lean it out and now it idles great.
For info on scanning and programming check out the DIY PROM forum.
