New LTR ET's
Old Sep 7, 2005 | 08:24 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
New LTR ET's
R/T .708
60' 1.889
330 5.330
1/8 8.236
1000 10.749
1/4 12.877
MPH 105.83
Its a 383, TF Heads, 219 cam, ASM Runners and Edelbrock Base. LS1 Injectors, SLP headers and a Stock GM S-10 Converter. Chip from www.LSRacingChips.com Also running though the "screened" MAF and stock firebird CAI setup.
Used a set of the new MT ET Street Drag "Radials" and they sure did hook. I know theres more in the car so I have to find it with the help of Jamie and the chip burning place. Gotta love LS Chips being 30 miles away lol.
Old Sep 7, 2005 | 11:25 PM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Transmission: 4 speed Automatic
Axle/Gears: 4:10
Great times, I have a symilar setup, 383, TFS heads, slp runners, edelbrock base, 58mm TB, hooker shorties, 214 & 220 dur cam, vigilante 2800 converter, and 26x 10.5 MT ET streets, I'm still waiting to get a new timeslip, mabe in a couple of wheeks. Last time I was at the track, my best 1/8 mi run was 8.59 sec but that was on radial sreet tires, stock converter, and, stock chip. My runners and plenum are ported, but the base is not.
What kind of runners do you have? Any port job on your intake?
I hope my car can make it to low 8's on the 1/8, high 12's or even low13's on the 1/4 mi.
Keep up the good work and keep us informed
Old Sep 7, 2005 | 11:42 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I have stock Arizona Speed and Marine Runners. And my intake is port matched to the runners and gasket match to a 1205 for my heads
Old Sep 8, 2005 | 12:45 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
What kind of rear end you running? I'm worried my stock 10 bolt won't hang with that kind of setup (mine's going to be pretty simular) on Drag Radials....
What have you done in that department?
Any dyno's? What did you do with your transmission? Just the converter?
What about suspension mods?
Old Sep 8, 2005 | 08:01 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Stock 3.27 9 bolt. As far as suspension I have UMI Pnhard bar and LCa's. BMR Torque arm and relocation brackets. I dont know if they helped cause my friend who I was racing also pulled a 1.8 on his 91 Z with bone stock suspension and BFG Drag radials. The last time I went to the dyno it was before we had a good tune and it was 276 HP and 391 TQ. I'd love to see what it is now.
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Oh yea. Stock 86K tranny with just the converter.
Old Sep 8, 2005 | 09:36 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Not bad at all. You and I would make a good race. You have to change out the Firebird Cold Air intake system. That is a big restriction. I agree you have a lot more potential in your car.
Old Sep 8, 2005 | 09:45 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
There's more in that car. I was running those numbers last year with a similar 383 setup. Biggest difference would be I have a TPiS Miniram intake.
This summer I swapped to a set of 3:73's in the 9 bolt, and put the car on a dyno to tune it. Now I am running 12.4's @ 110+ mph all day. And just went 11.85 @ 114 on a rich 75 shot of "go-go-juice"!
Old Sep 8, 2005 | 04:17 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Mkos1980 - What track did you run at? US 42 or Norwalk?
You have a great torque motor there. A good winter project would be to port the base and retard the cam to 109-110 intake center. Retarding the cam will boost power in your mid to upper rpm while the port work will help overall power.
www.geocities.com/dzperf
Old Sep 8, 2005 | 05:10 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Norwalk.. At 42 I ran a 15 @ 105.1 with a 2.64 60'
Old Sep 8, 2005 | 08:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
you definately need a torque converter....
i'm running the same 1.88 60 foots on street tires as to your ET street slicks and i got a stock L98 with 2800stall LOL
nice times tho, but i would like to think a 383 TPI would trap 108 ...
Old Sep 8, 2005 | 08:21 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
i was able to stall it to about 2100-2200 but I would burn em bad. Most I could go was about 15-1700 and thats when I pulled the 1.8 I would hate to see the damage to the 9 bolt if it hooked at 2200 rpm and took off. lol
Old Sep 8, 2005 | 09:49 PM
Scott57350's Avatar
Car: 1991 Z28
Engine: 355 TPI
I was also out there with Mkos that day we ran together almost every time.
R/T ..405
60' 1.894
330 5.497
1/8 8.482
1000 11.078
1/4 13.264
MPH 103.34
I have a 355 with Vortec heads LT4 Hotcam
SLP Runner
Edelbrock Headers
Banks Cat Back
SLP 24 lb injectors.
I have no suspension mods done to the car except I just put new shocks on last week. I ran the BFG Drag radials.
Also the chip in the car is from Formato's Fasterproms so for a mail order chip I suppose it did pretty well prob will have it tuned
by LSR next spring so Im hoping for 12's
Old Sep 10, 2005 | 12:49 AM
Kennerz's Avatar
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
scott57350,
Do you have any port work done, I have a very similar combo.
Is your trany stock?
How do you like you're vortec - I really like the way mine turned out -
could alway use more power of course
Old Sep 10, 2005 | 01:56 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Seems as if all of a sudden the greater Cleveland area is producing some fast third gens....
Old Sep 10, 2005 | 06:56 AM
Scott57350's Avatar
Car: 1991 Z28
Engine: 355 TPI
Yes everything is ported but nothing to crazy with it. It is the Stock tranny I just have a shift kit in it and the GM S-10 style torgque converter. Stock rear end with 3.23 as well. Have you had your out at the track yet?
Old Sep 10, 2005 | 08:21 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Wait till I get done with my GF's 89 RS with the 350 TPI in it
Old Sep 10, 2005 | 08:07 PM
Kennerz's Avatar
Scott57350
No times yet, looking to get to the 1/8 mi racelegal events we have here in San Diego.
The only 1/2 mi tracks are in LA, I'm not sure if people still run at carlsbad.
Old Sep 10, 2005 | 08:39 PM
Car: 1989 GTA
Engine: 369 TPI
Carlsbad is closed. There are some 1/4 mile track in the LA area. Our club races at California Raceway in Fontana. Next race in two weeks on Saturday.
Old Sep 10, 2005 | 11:06 PM
GOY's Avatar
GOY
I know it's the wrong forum, but since we have so many Ohio guys in this thread...
If you are looking for an LB9/M5 toy to mess with for little money https://www.thirdgen.org/techbb2/sho...hreadid=320264
lt500r55
Sep 1, 2021 01:30 PM
stalkier
Dec 6, 2015 11:25 PM
TRAXION
Aftermarket Product Review
26
Sep 21, 2015 07:47 AM
TRAXION
87
Nov 22, 2008 10:33 PM
CrazyHawaiian
May 30, 2001 02:50 AM
