comp cams 1.6rrs , Edelbrock 60859 heads, Crane 2032 cam, What pushrod length?
Old Sep 7, 2005 | 08:46 PM
merc3065's Avatar
Car: 87 GTA
Well as the title says, I am in the middle of an '88 L98 350 build up and I was given the wrong pushrods (im sure of it because they are actually smaller than the stock ones I pulled out @ 7.049" vs 7.200").
Is anyone running the same setup with the CompuCam 2032 cam, Crane's OE style hydraulic roller lifters, CompCams aluminum 1.6 ratio RRs for center bolts, and Edelbrocks #60859 heads.
If you are using that setup or something very similar, what length pushrod did you use? Stock sized 7.200" or did you go .100" longer with a 7.300" like the instruction pamphlet with the heads said to use for stamped 1.5 ratio stock rockers.
If someone is running the same setup, and has done some of the leg work of figuring out what to use, that time savings would be helpful.
However, if I have to go get a measuring tool, then that's what i'll do (would prefer not to as im already over budget with little things, stupid gaskets )
Old Sep 7, 2005 | 09:08 PM
TommyG's Avatar
Car: Chevy
Transmission: 700R4 Automatic
The Answer to your Question is.
I have this set-up but I am changing my profile a bit What you need is Comp Push rods from summit Part # 7808-16. I had no problems.
Old Sep 7, 2005 | 09:24 PM
merc3065's Avatar
Car: 87 GTA
Wow, they aren't much different than stock ones. Go figure...
Now to order them Thanks!
Old Sep 8, 2005 | 11:30 AM
TommyG's Avatar
Car: Chevy
Jake_92RS
Jan 28, 2020 10:37 PM
michealleger
Aug 26, 2015 03:29 PM
mz92274
Aug 25, 2015 08:47 AM
hayesaw0210
Aug 23, 2015 11:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
