TPI intake
TPI intake
The same old question. Which way is the best way to go when adding an cold air intake to a 86 tpi with a 383 stroker and bunch of goodies. Should I go for slp's kit for $250, custom make one, just cut the current box up to free up flow to the 2 k&n's I currently have in there, or any other ideas? Also do you any of you know what kind of gains these different methods are making. Thanks for you help.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
You don't really gain much, 10hp on a built engine maybe? Making your own is simple, probably $15 of tubing and an hour or two of work.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
