What Plugs to use???
Old Sep 9, 2005 | 10:05 PM
mcwpns's Avatar
Car: 1989 firebird/91 tpi formula
Engine: 327 small block/305 tpi
Transmission: 700 R4
Axle/Gears: superior axles/3.42's
Just curious what plugs everybody's using or whats best for an LB9. I was running R45 ac delco's and the car seemed slow under 2800 rpm. Swithed to a set of rapid fires and picked up some bottom end but it just does'nt rev as fast as it used to.
Old Sep 9, 2005 | 10:08 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
NGK plugs work very well in mine with TPI
Old Sep 9, 2005 | 10:56 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Delcos gapped to .035 I believe.
Old Sep 10, 2005 | 09:27 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Eather your old plugs were horrible or something , but rapid fires are not going to give you an extra advantage. If so, everybody here would run them. Basically most use stock AC's like myself.
Old Sep 10, 2005 | 02:03 PM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
I currently have the standard AC plugs, but considering the chore to change them it might be worth thinking about platinum plugs. No expectation of a performance gain, just longer life....
I've also had good results with Autolite plugs.
Old Sep 10, 2005 | 07:19 PM
mcwpns's Avatar
Probably going back to the ac delco r45's. Thanks guys
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
