Not hitting WOT
Old Sep 13, 2005 | 09:34 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Not hitting WOT
I don't think my car is hitting WOT. I can be cruising at 20 mph, mash the gas and it only downshifts to 3rd out of OD, not 1st or even 2nd like it should. Feels like im only going 90 pecent of the way down?? Ive noticed on my other cars when i hit wot it goes nuts, my car doesnt seem to do anything..
Old Sep 13, 2005 | 09:53 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Maybe the detent cable needs to be adjusted.
Old Sep 13, 2005 | 10:10 PM
Can you explain more on this?
Old Sep 13, 2005 | 11:16 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
TV operation
Check this out.
http://www.tvmadeez.com/article/index.php
Read the whole TV 10 article, it is very informative.
Old Sep 14, 2005 | 08:54 AM
brutalform's Avatar
Also make sure the throttle cable is opening the butterflies fully, when you mash the pedal. Have a friend look at it while you mash it. It does sound like the TV cable though.
Old Sep 14, 2005 | 05:45 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Checking that the blades open fully is a two person job. Remove everything in front of the TB. Then with one person in the drivers seat press the pedal to the metal. Have your buddy then visually verify that the blades are fully opened. This is a good point.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
Damon
Sep 26, 2015 04:29 PM
