How fast have you gone with stock 305 heads (not necessarily on a 305 engine)
Old Sep 15, 2005 | 04:37 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I have a stock set of 416 (early 305 tpi perimeter bolt) heads on my 327 because the 58cc chamber gives me around 9.6:1 compression w/ flat top pistons. The 1.84 valve size is a little small considering my cam size but not the end of the world -- the short stroke 327 will pump less air per stroke than a 350 would. I also have a set of 081 heads (nearly identical to the 416 but better spark plug placement, and center bolt valve covers) that I will end up porting at some point. However, for now I am running the 416s uncut. My combo is the following
1967 327, .030 over
Holley Stealth Ram
I burn my own chips and datalog
Isky 280 HL flat tappet hydraulic Cam (.485/.485 lift, 280 adv duration, 232 @.050) Manufacturer's rated powerband 2500-6800 rpms. I usually shift around 6300
untouched 416 (305) heads 1.84/1.5 stock valves
dual mandrel bent 2.25" exhaust w/ dynomax race magnums
BW World Class T5
3.73 gears
This car ran 14 flat spinning really bad, at 99 mph back when it was carbureted and had 350 open chamber heads (7.8:1 compression) and had the same cam -- it was waaay overcammed for the compression and had a muncie 4 spd, but still ran that well. I haven't been to the track yet but the car definitely runs stronger with the multiport EFI, great tune, and compression ratio that matches the cam a lot better.
How fast has anyone gone with STOCK 305 416 or 081 TPI heads? Carbureted vehicles included. I'm especially interested in non 305s w/ stock 305 heads, but 305s count too. Also how fast have you gone with midly ported, STOCK VALVED 416 or 081 heads.
Thanks!
Old Sep 16, 2005 | 10:46 AM
Car: 2000 BMW M5
Anybody?
Old Sep 17, 2005 | 08:42 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
On my 305 I had stock 081 heads and was running 13.80'S with bolt on's and 99 MPH.
Old Sep 17, 2005 | 09:21 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
my 081 heads had larger valves so I was not stock
Old Sep 18, 2005 | 09:54 AM
Car: 2000 BMW M5
Thanks guys. Sounds like these heads are not the end of the world when I expect to be running high 13s.
Old Sep 18, 2005 | 10:54 AM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
13.9 with stock 416 heads
Old Sep 18, 2005 | 11:09 AM
Car: 2000 BMW M5
Hey roughskin, are those 416s on the 350? Thanks
Old Sep 18, 2005 | 11:31 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yeah 350
Old Sep 18, 2005 | 02:29 PM
brutalform's Avatar
Stock 305 heads on a slightly modded 305, in a 92 Formula, went 13.90s, once! This was at a fast track (Island dragway), in great air. Normally, the car ran 14 teens all day long.
Old Sep 18, 2005 | 02:30 PM
brutalform's Avatar
[B]
Wow! I just realized how old I'm getting. That was a long time ago.
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
