Where's that ESC Module
Old Sep 15, 2005 | 08:08 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Working on a 89' 350 TPI here. Awile ago i was getting a code 43. It seemed to have went away when i put a MSD box in.(The code at least) Anyways the car always wants to backfire a little bit,but only on deceleration,and i have noticed that it has a faint popping noise when it idles,nothing sever but you can still here it. I went and bought a new ESC Module and i thought it was located on the back fire wall near the maf power/burn off and fuel pump relay, but the part they gave me doesn't look anything like the module behind those.. Is it safe to assume that the module i am looking for is located on the distibutor where the 4 prong and 2 prong pigtail lead in from the coil?
I also decided to replace the knock sensor just in case because the distributor is only a few years old and i can't even remember anymore if i put the 350 knock sensor in when i replaced the motor. Any help would be appreciated.
Old Sep 16, 2005 | 03:15 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
ESC module is by the relays you mentioned. Sounds like they sold you an ignition module. Thats the part that goes in the dist.
Old Sep 17, 2005 | 11:50 PM
Car: 92'Camaro RS
Engine: a loud one
Thanks 92 blue.....you were right......part # i need was ESC 100.......boneheads
InfernalVortex
Apr 20, 2021 11:31 AM
L98GTA87
Oct 19, 2015 10:43 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
RGB2015
Sep 20, 2015 09:26 PM
