Swapping from TBI to MAF TPI
Old Sep 19, 2005 | 08:33 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I've seen a lot of swaps to speed density TPI but what about using MAF? Isn't this method more accurate and real time based than a preset group of tables? The LS1 and later LT1 cars used it and it ran great. With proper dyno tuning wouldn't that be a good alternative for TPI?
Old Sep 19, 2005 | 06:14 PM
robertf's Avatar
Car: Land Rovers
Engine: 3950cc
Transmission: some autos, some manuals
Re: Swapping from TBI to MAF TPI
probably best if you just search, but here is my 2 cents...
MAF is great if you can't tune, speed density is great if you can.
speed density is hardly a lookup table, there is much more too it and it is also a little faster in response to changes when compared to a maf sensor.
LS1 and LT1's use both, and many people are disabling the MAF and running full time speed density on those pcm's.
Old Sep 19, 2005 | 06:35 PM
Mongoose's Avatar
Car: 90 Formula
I knew that MAF was more forgiving when mods were applied. I was also unaware that LS1s used speed density,though I know that LT1s used SD in 93 but went to MAF in 94. As for the tables that was just a very basic description,I know there's way more to it than that. I've got access to a MAF TPI and was looking at running it that way if it could be improved on like the 4th gen cars can without going to SD.
xkingcodex
Feb 12, 2020 07:43 PM
NBrehm
Aug 25, 2015 11:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
