1991 Z28 reads high voltage
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
CAn someone help me out with my situation. I just installed the control module, pick up coil, ECM & Prom. Also, changed the distributor. But the wierd thing is when I start the engine, then she shut offs... What happended in hmy situation?
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Assuming you installed the control module, pick up coil, distributor correctly. Make sure you have you're EPROM installed in the socket correctly. I know if the EPROM is in backwards the car will start then shut off.
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
my mechanic figured out the problem, either the short is coming from the distributer or the wiring from the ecm.. Everytime i connect the balancer, wattever its called, my motor just shuts off after i turn it on...
eightsixseven
Dec 16, 2024 01:50 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
db057
Aug 11, 2015 10:11 PM
