Engine mods
Old Sep 28, 2005 | 07:13 PM
RED5SPDFORM's Avatar
Car: 1989 Pontiac Formula
Engine: 305 tpi
Engine mods
I plan on buying some parts to upgrade the car. Im looking a two different sets of headers, SLP and Edelbrock. I already have SLP dual side exit exhaust on the car. Dont know which set is better. As for the air intake theres only one choice that I have seen, SLP cold air. Plan on going with a B&M short throw shifter. Looking at Splitfire triple platnum plugs along with Taylor spark plug wires for a possible better spark.
Old Sep 28, 2005 | 07:23 PM
llvll4l2c91350's Avatar
i have the edelbrocks. cheaper, easy to install.
SLP's is better quality, more expensive and hard to install from what i hear. the tubing is also bigger.
my edelbrocks will be for sale as soon as i get a chance to remove stock exhaust from another bird so i can use it on mine. ima be putting the stock manifolds back on.
Old Oct 1, 2005 | 05:49 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Go SLP for the best . I love mine . I have the B&M short throw shifter ( Ripper ) .It's not really short . But it's a naice notchy positive feal . The other shifters I think you can get an actual shortter stick without haveing to cut it .
good luck man
Old Oct 1, 2005 | 07:12 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Why not make your own intake system, and spend the few hundred on some SLP Runners and port them
Old Oct 2, 2005 | 12:45 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
The SLP 1 3/4's took my car from a 15.2 down to around mid to low 14's. IMO they are worth the time and effort for a mild modded car. If you plan to do anything serious I would do your light modds elswhere for now and get longtubes when you go for heads and cam exc.
Old Oct 2, 2005 | 07:52 PM
Engine: 305 tpi
Hey thanks for the advice with my car. The only thing I am going to do to my car is just headers, intake, and possible chip and the b&m shifter. Thats the only thing I plan on doing to that car since it has low miles and I want to keep it stock well somewhat.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
NWAsonoma
Aug 18, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
