headman headers install HELP PLEASE!!
Old Oct 4, 2005 | 08:21 PM
ibwsjerry's Avatar
Car: '89 iroc
Transmission: th-350
its a 89 iroc w/ shorty headmans.. Drivers side is real hard to get in. It hits the stearing shaft and valve cover from top, try from under it hit the oil filter and oil sending unit?? What did you guys do to put your in?! thanks guy
Old Oct 4, 2005 | 08:34 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Well it's beem about 12 years since i put mine on. But if i remember correctly. I did mine from the top on the drivers side and the passangers side from the bottom. Big help for me was to loosen the motor mounts and jack the engine up. Loosened the motor mounts put a small piece of plywood on the oil pan and jacked the motor up. All in all i think it took about 5-6 hours to do. Granted at least an hour was spent scratching my head , throwing tools and aloy of profanity. I had the advantage of using a bay lift though.
Old Oct 4, 2005 | 11:07 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Take the valve cover off and it should drop right in. I have the Hedmans on my car. I also did the motor mount trick on the pass. side listed in the prior post. Took me longer to take off the manifolds then put in the new headers.
If you take off the valve cover it will give you that extra swing room to drop it in. I also pulled the alternator for a more open work area.
Old Oct 5, 2005 | 12:50 AM
ibwsjerry's Avatar
Car: '89 iroc
ok, valve cover isnt so bad. Luckily for me i have no a/c, no blower motor, no nothing on the pass. side of car so it drops right into place o). But the drivers side is tight. I had the edlebrock headers and they pulled out with a little force but the headman's are bigger. Any more ideas?? Thanks for the help otherwise guys.
Old Oct 5, 2005 | 07:16 AM
ncgator's Avatar
Car: '89 Trans Am
Axle/Gears: 9 bolt 3.23 posi disks
listen to what they told you... take the valve cover off and loosen the motor mount on the drivers side then jack it up. i only had to jack mine up about 1cm and it dropped right in.
Old Oct 10, 2005 | 11:00 PM
plathegame's Avatar
Car: 1986 trans am ws6, 66 grandprix
Engine: 88 iroc 5.0 tpi
Transmission: 700 r4 built by rocky pirrone
Axle/Gears: 327
i just put a set of these on last month on my t/a..
all i did was took the valve cover off and took the bolt out of the steering shaft that is just below the booster so it would flex a bit when i gently pryed on it and it fell right in w/ no problems
Old Oct 11, 2005 | 12:10 AM
ibwsjerry's Avatar
Car: '89 iroc
just put mine in tonight. Pulled out the stearing shaft bolt, took off valve cover and pryed up between the motor mount to flex the motor a bit and it went in pretty easy. But now #3 plug you cant get to unless you make a plug socket with a cut away in it. Now comes the pass. side. Just setting it in, it already hits the frame?! So i guess a put a little notch with a B.F.H.
Old Oct 11, 2005 | 09:40 AM
plathegame's Avatar
Axle/Gears: 327
on the pass side i took off the plastic blower motor case, dip stick tube ,ac drier, valve cover, starter and the alternator & brackets and it went in w/o touching the mounts, or boogering up the header..
Old Oct 12, 2005 | 12:13 AM
ibwsjerry's Avatar
Car: '89 iroc
finished up. Since i dont have air or a blower my pass. side is completley naked and went right in. ALTHOU i did have to "ding" the primary tube on the header a little because it was hitting the frame rail, but it was only like 1mm ding so nothing too serious. Y-pipe went in smooth, fit like a glove!! Now i just need a pipe to take place of the cat, fuel filter and goin to the track on sat. to see what she runs!!
Old Oct 14, 2005 | 05:55 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Had no problems replacing the TES headers with Hedmans once I removed the tall valve cover for the drivers side.Had to remove the valve cover,starter & AIR stuff on the pass side.Both dropped in from the top.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
