Bouncing Tach...
Car: 08 Nissan Altima
Engine: Stock
Transmission: Stock
Bouncing Tach...
MY car has been running a bit rough lately, and I noticed a misfire... the misfire is in sync with my bouncing tach... when the tach bounces, it bounces up, not down, when it does, the car misfires. Im going to perform a tune-up soon, but Im sure that wont fix my bouncing tach. Im guessing loose connection, where should I start?
92 Z28 - TPI Stock.
92 Z28 - TPI Stock.
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Ingnition module (in the distributor). Check for burnt/arcing spark plug wires also - arcing can make the tach bounce. The module could be going out, or the connection is loose. Replacing an old one is always a good idea with modules, if you need more convincing.
Good luck.
Good luck.
Car: 1986 trans am
Engine: 305 tpi
Transmission: th700r4
my tach used to bounce like that. mine got so bad that the car would almost stall. i found out that i had some bad injectors. after i replaced them the car ran fine. might be somthing for youto check.
buckeyecelt
Sep 24, 2015 05:50 AM
