IAT Relocation Question
Old Oct 11, 2005 | 10:37 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I was thinking of moving the IAT to the intake box like suggested by some people I have talked to. How does this actually work? Do I just remove my current IAT sensor, drill a hole in the intake box, install the sensor, then plug the harness in it? Since the IAT would been then located in the intake box....there would be a hole in the bottom of the intake, does that need to be covered or plugged with something? Just wanting to make sure before I decide to buy it or extend the wires. Thanks
Old Oct 12, 2005 | 01:28 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If u read the code and truly understood its function, you would be wise to leave it as it is.
If u wish to delve into the specifics, hit the prom board and search for relocated IAT and you will see what I mean.
later
Jeremy
Old Oct 14, 2005 | 11:41 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If you can do some prom work, I would disagree and say it is worth it. Driving around in the summer in traffic, I saw the IAT hit 115* F. If it is tuned well to work at that temperature, that is fine, but I would rather it be tuned to take the reading of the incoming air than heatsoaking inside the aluminum plenum. That air was not 115* that the engine was recieving.
Ducati900ss
Sep 2, 2015 09:05 AM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
