*NEED HELP* Car start but die almost instantly!
Old Oct 13, 2005 | 02:15 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
I was gonna take my car to a paint shop for some ninor work in the engine bay to make it look better...
Yesterday I took the car to the paint shop to have the cost of paint evaluated. When I was coming back, the car was nearly dying at lights so I had to keep the foot on the gas and brake pedals. Sometimes I gived it some and the engine didn't reved higher when I was looking at my RPM tach. I put 10$ of premium fuel on my way home thinking maybe my dash wasn't showing me the right amount left in the tank.
Today when I was gonna go give my car to the paint shop, it started right up, ran for 2-3 secondes and died. Tried to restart it and started right up and stalled again. I did it for about 5 times and it always started and died. This summer I have replaced the cap, rotor, sparks plugs and the wires, air/fuel filters, battery...
It's not trowing any codes... What do you think is going on?
Old Oct 13, 2005 | 02:56 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
IAC valve and throttle body need a good cleaning. Try a search on IAT by the username VADER and you will get the correct procedure. If you don't know when it was done last then now is a good time. It's quite easy.
Check your fuel pressure.
Try those two for now and we can go from there if it didn't fix it. Report back on your findings anyway.
Old Oct 13, 2005 | 03:28 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I wan't to try cleaning my IAC and throttle body. But I can't seem to find the tech articles with the search engine.
Can I just spray the fluid in front of the TB while I give the motor some gas?
Old Oct 13, 2005 | 03:29 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I no mechanic, I all did in my life is change my battery, air filter and cap and rotor. Did not even change the spark plugs and wires since it looked like a pita...
Hope I can try some things myself before taking it to my mechanic.
Old Oct 13, 2005 | 03:45 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Like halfinchwrench said, check fuel pressure and get yourself a $6 noid light to see if the injectors are firing.
Old Oct 13, 2005 | 03:46 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I will go buy some stuff at Canadian Tires tonight. Someone can help me find the tech articles to clean the TB and IAC? Should I clean my plenum, runners, etc too?
Old Oct 13, 2005 | 04:00 PM
Car: 92'Camaro RS
Engine: a loud one
https://www.thirdgen.org/techbb2/sho...le+air+control
Look for Razors response on cleaning the IAC
Old Oct 13, 2005 | 04:02 PM
Car: 92'Camaro RS
Engine: a loud one
Razor but Vaders
Old Oct 18, 2005 | 10:10 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Okay guys...
I cleaned the IAC and TB and it didn't helped.
So I took it to my mechanic and he checked out all the small things he could without finding anything. When he wanted to monitor what the sensors were reading and all, the car would always die and it even freezed his scanner! He never saw that he said! Happened 2 times. He tought it was either the fuel pump, computer or the EGR. He said to go to Canadian Tires to get it on a big machine so they can test it more. Canadian Tires found out it was my computer that was faulty. When the car was stopped, it continued to say the car was running at 500RPM. So they tried to give a couple of hit on the computer itself and the car ran fine, a couple other and ran bad and died like before.
Is this a common thing in our cars to happen? Do I need to change the EPROM too or just the computer itself and keeping my EPROM? Can I get another brand or should I stick with Delco? The guy at canadian tires say he can get a Niehoff brand computer for 150$. At GM dealer it's 248.75$. Can I buy it on the Internet for cheaper?
Old Oct 18, 2005 | 02:31 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Someone know the answers that were in my last post before I do something stupid? Thanks
Old Oct 18, 2005 | 06:42 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I would not take chances and just bite the bullet and buy the EPROM and computer. You could try aftermarket but I trust the factory stuff more. Plus if you get a new EPROM it will be an updated PROM and you will notice a difference in the way you car runs and drives.
Old Oct 18, 2005 | 08:32 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
That's what I tought, I should stick with Delco for the brand of the computer...
But do I really need to change the EPROM? It's only a stick with information, it doesn't have any wires and stuff like that it should be okay no?
They ask for 248.75$ (canadian) for a remanufactured computer from Delco. But I have to give my old one in exchange.
Can I find a remanufactured remplacement online for less?
Old Oct 18, 2005 | 09:07 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Do not buy an aftermarket reman. Junk Junk Junk I went through 4 of them before I got one that worked correctly without firing out a code or had a temp reading of 250* even when it wasn't running!! Gm remans are made by the same company. I know my brother is a gm parts guy, and I had to listen to him say "I told you so"!! Get a brand new GM computer and reuse your prom. It will cost a little more but there is a BIG quality difference.!!
Old Oct 18, 2005 | 09:19 PM
Engine: SBC, LS-x
GM stuff only in my opion. Don't buy anything made by Niehoff, that stuff is garbage.
Old Oct 18, 2005 | 09:26 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
So a gm remanufactured one is all right? I don't need a brand spanking new one?
Old Oct 18, 2005 | 09:44 PM
Engine: SBC, LS-x
A working used one would be fine or a reman. from GM. I didn't think GM made new ones. Do they?
Old Oct 18, 2005 | 10:12 PM
subroc's Avatar
Engine: 355 TPI
Nope you cant get a new ECM anymore. Best bet is a GM remanufactured. I would get a new prom if i were you because with the updates over the years your car will run better and shift smoother. I put a new computer and PROM in my car and noticed a huge difference in the way the car ran. Its not that it was any faster, but it just ran smoother. Not to mention it shifted better as well. Its up to you of course but my two cents is by the updated prom as well and cross that off of your list of possible problems.
Old Oct 19, 2005 | 09:30 AM
Damon's Avatar
Before you throw money at the problem try at least one quick diagnostic test first- unplug the MAF sensor (round sensor in the intake hose between the TB and air filter housing). Sometimes a MAF will go bad and give you a start-then-stall problem. ECM doesn't look at the MAF until the engine is over 250 RPMs. So when you're cranking on the starter it's not looking at it. As soon as it fires up it looks at it, gets a bad reading, injects the wrong amount of fuel and the engine almost immediately dies.
It's a long shot, but worth a quick check. Unplug it and fire it up. If the MAF is bad it'll suddently run about 90% better. Don't drive it around much like that- it's only a quick diagnostic check, not a fix. Longest you should drive it like that would be to the parts store to buy a new MAF.
Old Oct 19, 2005 | 10:28 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Not a bad idea, I'll have to check it out. Thanks!
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
killer777
Aug 8, 2015 02:47 PM
