19 lb/hr injectors on a 350 with injector constant change?
Old Oct 14, 2005 | 07:56 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Hey guys!
Will I be running into any major problems if I adjust my prom's injector constant to 19 lbs?
I can't afford a set of 24 lb injectors yet, but have a good set of 19 lb injectors. I don't plan on driving the truck on the freeway this way, just around the block once I get driveshafts and such installed.
Old Oct 14, 2005 | 08:28 PM
Vader's Avatar
It should run fine, and may even work acceptably at higher RPM so long as the pressure is adjusted. I worked on a '57 BelAir that had a 355 TPI and 19/Lb injectors. I lowered the injector constant to somewhare around 18.8, and it worked rather well up to about 5,800 RPM.
Old Oct 15, 2005 | 12:10 AM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Axle/Gears: 4.10
Cool, my TPI has a mild cam, so it'll need more fuel in the upper end, but if it'll work for now, sounds like a good deal!
Thanks!
Russ
jklein337
Sep 19, 2018 06:23 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
tmellott89
Aug 16, 2015 02:58 PM
