code 13 problems
Old Oct 18, 2005 | 01:15 AM
pawcio's Avatar
Car: GTA 89
Transmission: TH700
Axle/Gears: BW 9 bolt
code 13 problems
Hello all
This code will flash when engine reach operating temp and go to closed loop. I replaced the oxygen sensor with new one....and no effect
car was running lean imho, bad fuel pump maybe?
Old Oct 18, 2005 | 06:18 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Code 13 usually indicates a fault with the sensor or sensor circuit. If it was running lean, typically a code 44 will set.
With the Key On and Engine Off, unplug the Oxygen Sensor connector and measure the PCM side of the connector with a Digital Multimeter. You should have 450mV +/-. If not, then there is an open circuit in the wire or the ECM is faulty.
Old Oct 19, 2005 | 04:00 AM
pawcio's Avatar
Car: GTA 89
Transmission: TH700
Originally posted by GMTech
With the Key On and Engine Off, unplug the Oxygen Sensor connector and measure the PCM side of the connector with a Digital Multimeter. You should have 450mV +/-. If not, then there is an open circuit in the wire or the ECM is faulty. [/B]
Hi
I do that - multimeter reads 0.95V with the ignition on....
Old Oct 19, 2005 | 03:42 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Originally posted by pawcio
Hi
Thats on the ECM side of the harness with the sensor unplugged? If so, borrow another ECM and re-measure. If its not within a few millivolts of 450, then the ECM or circuit is bad.
chazman
Aug 28, 2018 03:25 PM
db057
Sep 4, 2015 07:57 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
