accel base
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
accel base
i just got an accel tpi base, are there special washers for the 4 center bolt holes? i have an 87+ so how did you guys install it?
Car: 92 Z28 Camaro
Engine: 350 TPI : Supercharged
Transmission: TH700R4
I too have the Accel base with SLP runners. I just re-used the factory bolts from the original base. If you have not installed yours yet, you really need to upgrade the runners also. Good luck with it.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
check ebay and the classifieds on this board. you'll come across them.
for the money i dont think they are worth 450-550 bucks brand new. too much room for porting, doesnt seem to justify buying it new and having to port it. there is alot of room for gain
Car: 92 Z28 Camaro
I ran across mine on e-bay for $300, and it had never been installed. If I had it over again I would have gone with the Holley Stealth Ram. But I did some port work to my Accel base and upper plenum, and smoothed out the inside of the SLP runners. It feels very good on the bottom end, which with the stealth ram I have heard you lose a little on the bottom but it really shines in the upper rpm range.
Re: accel base
The beauty of the Accel base is that it will work with late model and early model Gen I small blocks, it has room for porting, and it flows as well or better than any aftermarket TPI base. It is as good an aftermarket TPI base as you can get.
My $.02
efiguy
Sep 27, 2015 01:30 PM
