help with part
Old Oct 26, 2005 | 02:30 PM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
help with part
i am trying to find what ing module (in the dist) that i need
It is a 86 TA with a 350.
I still have the 305 module in now.
Will this work?
If not than what module do I need?
I tried geting a module from a 88 with a 350 but it didn't fit
(it was not coil in cap, but mine is coil in cap)
Old Oct 26, 2005 | 10:12 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I don't see why the one you have wouldn't work.
Anyway, I use this page sometimes to look up info on modules:
http://www.megasquirt.info/ms2/GM_7pinHEI.htm
There are some part numbers of modules there. Sounds like you have the 7 pin (large)
Old Oct 26, 2005 | 11:49 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Same module used. If it worked before then it should now with a new engine around it.
Old Oct 27, 2005 | 11:46 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
the engine was swaped from a 305 TPI to a 350 TPI
So am I right in hearing that the 305 module will work with the 350 motor?
Thanks again
Old Oct 27, 2005 | 08:29 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
it is the same module for both engines
Old Nov 2, 2005 | 09:29 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
great thanks
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
