Wich used MAF can fit on my GTA?!
Old Oct 31, 2005 | 03:06 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
I know someone that is selling a used MAF from a 305 TPI Camaro... The thing is it's that the part # says it's only for 86-87 TPI. Will it works with my 88 GTA 305 TPI anyway? Even if it's not the same part #? Because sometimes company changes the # but that's the same part...
Thanks!
PS: I need a straight answer. No guess... Because I don't have much cash to spend and I don't wan't to buy a MAF that won't works right or at all with my car.
Old Oct 31, 2005 | 05:57 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
My '89 ran just fine with the maf sensor from my '86 in it, and vise-versa. As far as I know they are the same part number.
Old Oct 31, 2005 | 08:06 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Because the MAF from the guy is GM part #14094712... Web sites says that it fit 86-87 Camaro/Firebird with TPI only. So will my 88 GTA work with that?
Anyone else can confirm. I don't wan't to spend 200$ for the fun...
Old Oct 31, 2005 | 09:57 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Ummm, you're paying $200 for a used MAF?? Why don't you try going to the parts store... You can get a reman MAF with a warranty for less than that...
Old Nov 1, 2005 | 07:23 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
It's because it's near new. The guy used it 2-3 times. GM sell it for 756$ (canadian) here... So I think it's a pretty good deal for an original one. I just wan't to know if it will work since this # say on the 'net it's for 86-87 TPI...
Old Nov 1, 2005 | 11:50 AM
Ragtop89's Avatar
Are the Wells MAFs still available?
https://www.thirdgen.org/techbb2/sho...ight=Wells+MAF
Old Nov 1, 2005 | 01:45 PM
84frbrd's Avatar
Car: 1985 trans am
Engine: 5.7 tpi
Transmission: 700-r4 with b&m trans pack
.......ummmm i have worked at oreilly auto parts for a wile now and you can get a remanufactured maf from a1 cardone for around $225 exchanged with a lifetime warranty
Old Nov 1, 2005 | 02:14 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
O my *** 756.00 canadian for a maf, my buddy got one from the boneyard for 15.00 us.
Old Nov 1, 2005 | 05:30 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Hmmm, I made some calls today and the cheaper ones are around 500$ (canadian)...
So anyone know if a 87 TPI MAF would work on my 88?
The part # says it's for 86-87 but I would like to know for sure... If it works I'll buy it it's cheaper and it's near new...
Old Nov 1, 2005 | 07:39 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Holy cow man, go to ebay or something. You can get an adjustable aftermarket MAF with a lifetime for like 250 bucks US!
Old Nov 2, 2005 | 07:33 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
No one still know if a 87MAF will work on my 88? I just need a replacement...
Old Nov 2, 2005 | 08:49 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
It will work.
Old Nov 2, 2005 | 08:57 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Then why do the part # says it's for 86-87?
Old Nov 2, 2005 | 09:01 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
The engineer that help design the system at gm told me that they function exactly the same. I relayed this info to you. I have interchanged them many times with vette's and fbodys. I don't know why the numbers are different. It does not matter to me. If you are in doubt, I would suggest you put the same one on the car that it calls for.
Old Nov 2, 2005 | 10:03 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Ok, I'll buy it then. Thanks!
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
86IROC112
Sep 7, 2015 01:37 PM
trevor1010
Aug 24, 2015 11:29 AM
Bert87
Aug 23, 2015 03:50 PM
