LT1 intake elbow on TPI?
Old Oct 31, 2005 | 01:58 PM
sauer_power's Avatar
Car: 82 Firebird SE
I've seen a lot of nice aftermarket intake elbows for the LT1 and I was wondering if they will fit on the TPI?
Old Oct 31, 2005 | 02:18 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Yes. I was wondering the samething
Old Oct 31, 2005 | 06:54 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Like in the picture.
Old Oct 31, 2005 | 07:51 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Why would you want that to be under the hood sucking in all that hot air?
Old Oct 31, 2005 | 08:02 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Looks like there's a metal shield....when you close the hood the filter should be totally isolated from the hot air.
Old Oct 31, 2005 | 08:06 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Then what do you have bringing in cool air? That obviously doesn't seal, it could easily just suck the air through the gaps into filter. Not saying it doesn't work, just curious, seems like there's more to that then what we can see, and sucking in hot air is no good, i did that on my 3rd gen it was a waste. But I didn't attempt to seal it off at all and I had no way for fresh air to get in. So I plumbed the original stuff cut out the bevels used some heavy duty metal dryer hose to bring in air from underneath the front spoiler
I'm sure there's more to this setup than what we can see I just wanna know what.
Old Oct 31, 2005 | 10:51 PM
Car: 1989 GTA
Engine: 369 TPI
Yep, it draws in the cool air from the fender well area like on the SLP cold air kit. Like was stated the air filter is sealed off from the rest of the engine compartment.
What you don't see is the foam on the underside of the hood to seal the top part when the hood is closed. Also you do not see the rest of parts that seal off the area. If you look closely you can see the foam between the radiator overflow container and the fender that seals off that part.
Old Nov 1, 2005 | 08:31 AM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
I knew htere was more too it then what we could see
Terrell351
Jun 13, 2021 01:13 PM
midge54
Dec 27, 2019 04:14 PM
toronto formula
Nov 10, 2015 06:17 AM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
