Cant find aftermarket heads for a 91 L98
Old Nov 14, 2005 | 06:26 PM
91_B4C_RS's Avatar
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
ive searched the internet looking for some aftermarket heads that fit the 91 L98. It doesnt say anywhere in the description of them what years they fit.
some links would be great.
thanks
Old Nov 14, 2005 | 08:20 PM
5.7tpiroc's Avatar
Car: 89 Iroc
Engine: 5.7tpi
Axle/Gears: 9 bolt posi w/ 2.77s
you could always try to find some aluminum 'vette heads! that's what i'm trying to do! or some vortec's!
Old Nov 14, 2005 | 08:39 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Any heads that have the 87 up bolt pattern and egr passages will work on your L98.
Old Nov 14, 2005 | 08:55 PM
91_B4C_RS's Avatar
i have no egr. i am runnin a lt1 converted intake with the l98 bolt pattern.
i cant find a description of what year the aftermarket heads fit so i can find the right bolt pattern.
Dart iron eagles ETC. doesnt say what bolt pattern they have.......
links please
Old Nov 14, 2005 | 10:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
trick flow heads will fit and work great with LT1 intake. it has the egr passages and fits 87 up. believe they have angledplugs to fit l98 as well
try summit racing for these heads
AFR has probly the best heads with EGR passages and without for L98's and the angled plugs too.
www.airflowresearch.com
Old Nov 15, 2005 | 02:31 AM
83 Crossfire TA's Avatar
Slot the center bolt holes on the intake and you can use any traditional SBC head, 87 and up used different bolt angles for the center bolt holes (I supposed that you can use an ’85 or 86 manifold base if you want to use older heads also)
Later vortec heads require a vortec manifold base.
Angle plug heads tend to be a headache with most headers
Old Nov 15, 2005 | 06:09 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
There are many heads for your car, I cant beleive that you cant find any,,, AFR,,, Trick Flow,,, Edelbrock,,, Patriot Performance.
Go to Summit Racing's site and check out multiple heads for you.
CRFred
Feb 7, 2016 11:39 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
ZsTransAm
Aug 11, 2015 07:30 PM
anesthes
Aug 8, 2015 09:37 PM
