9th injector staying on?
Old Nov 20, 2005 | 11:58 AM
m300slr's Avatar
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
I just changed my 305 tpi from a 85 to an 86 computer. Now finaly my car starts on the first try. But when it does, it wants to stall and bogs down when I give it gas. Almost like it is running way too rich. So I decided to unplug my 9th injector now The car starts slow on cold start, but runs great once started. So I can only assume that maybe my cold start switch is bad (on all the time). Any body have any ideas.
Old Nov 20, 2005 | 02:06 PM
Vader's Avatar
The cold start valve may be powered up when it shouldn't be. The control for the CSV is a combination temperature/timer that will allow voltage to the CSV for a given length of time at a given coolant temperature. It is a completely analog device, and may well have gone out of range. You can test the cold start control with a voltmeter connected to the injector (valve) while the engine starts. If the voltage remains present for more than a few seconds, the control is screwed. Once the injector has been fired, subsequent start attempts should not produce any voltage at the injector, at least until the "timer" half of the control has been allowed to cool between starts. That may take 5 minutes or more.
It seems you've isolated the problem to the cold start pretty effectively.
Old Nov 20, 2005 | 02:48 PM
m300slr's Avatar
Car: 1985 Z28
thanks vader, I will try that.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
