Putting in injectors, what gaskets will need to be replaced?
Old Nov 21, 2005 | 02:34 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
LIke the title says, I will be installing some bigger injectors pretty soon and would like to know if I will have to replace tpi gaskets. While I'm in there will I need to replace the TB gasket as well? Where can I find some cheap, like does Autozone carry them?
Old Nov 21, 2005 | 02:40 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
I just replaced the injectors on mine and the only gaskets I needed were for the upper plenum and the runners. Wasn't to bad.
Old Nov 21, 2005 | 03:58 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Nope.
Go to Autozone or whoever else carries fel pro gaskets and get the upper plenum gasket set.
U wont need the TB gasket but is is included, just no real reason to take it off, just disconnect everything from it.
Dont forget to lube the injector o-rings and make sure your egr is clean when your there, since your at the halfway mark for yanking the intake as a whole
later
Jeremy
Old Nov 21, 2005 | 07:58 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
maybe replace that Fuel pressure regulator if its org one too. since you're already there
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
justin57
Aug 20, 2015 07:05 PM
MY87LT
Aug 17, 2015 08:43 AM
mizz0313
Aug 12, 2015 06:45 AM
