Coolant getting in oil
Old Oct 23, 2005 | 06:52 AM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
guys
I just bought a 91 z28 5.0L tpi car. I was told the car had a fressh 350 engine that was bored .040 over. anyhow i bought the car from a friend because it's getting coolant in the oil.
What i want to know where should i start checking to find where the leak is. I don't think it's head gaskets due to the fact there is not any compression in the radiator blowing the coolant in the overflow tank.
BTW if i have to put a engine in it . i got the car for a song 1000 bucks so i can afford to spend some monies on it
Old Oct 23, 2005 | 08:45 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Intake or head gasket. Or worse, cracked block or cracked head.
Pull the plugs and see if you find a "clean" one.
Pressurize the cooling system and check for leaks.
Old Oct 23, 2005 | 09:23 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I had the same problem. the intake is a mother on our cars and requires a bit of attention when placing it on the car. get new bolts use lock tight and wait about 20 min for the RTV to set before placing the intake on the engine after torqueing in the proper sequence let the car sit overnight.
Old Oct 24, 2005 | 10:09 PM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
If the car is an automatic it could be a bad radiator, the trans cooler for the automatic transmission is mounted inside one of the end tanks on the radiator, a small pinhole in this coolant tank can cause oil and coolant to mix with pressure differential changes in the oiling and cooling system at different RPM, check it out.
Old Oct 24, 2005 | 10:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That would be ATF then, not oil.
Old Oct 24, 2005 | 10:19 PM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
Your right.
Old Nov 20, 2005 | 11:43 PM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
head gasket
hey guys
I found the problem head gaskets. i tore the top end and pulled the heads and both gaskets were leaking.
one thing i noticed was i don't think the head bolts were torqued down to spec beacuse they didn't crack when i broke them loose it seem to me like it didn't take 40 ft lbs to break them loose.
could the stock bolts have relaxed from the heat from being to hot making them be loose?
Old Nov 21, 2005 | 08:01 AM
jamon8's Avatar
Engine: 350 tpi
yes they could have relaxed but they could also be worn out. spend the extra 30 dollars and buy new head bolts and while you are at it get new rocker adjusting nuts, these wear out too. take your time putting everything back together.
It takes more time to take it apart again than it does to really dial it in the first time.
Old Nov 21, 2005 | 09:07 AM
Merlin's Avatar
I could be mistaken (again) but isn't most "ATF" made of oil? Or are there special fields, rigs, derricks, and refineries that are dedicated to producing "ATF?"
Old Nov 21, 2005 | 10:45 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Originally it was made from sperm whales.
Old Nov 21, 2005 | 08:52 PM
Vader's Avatar
Whale oil in the transmission? THAT is probably my problem. The car sometimes feels like it's 60' long and weighs 80 tons. All I need is different oil?
Old Nov 23, 2005 | 06:03 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Are the heads aluminum ?
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
codeysabatini
Nov 10, 2015 04:07 PM
Stryker412
Sep 20, 2015 06:59 PM
