Need some measurements...can I even get a 3rd gen in the driveway?
Old Nov 22, 2005 | 09:16 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Hey guys I posted this on another board and haven't had a response figured maybe you guys can help...I posted it in TPI because I'm only considering TPI cars but mods if you want this moved to general tech go ahead. PLEASE someone get me an answer
Its close with my 4th gen TA. Can someone take some measurements for me? On a 90Iroc and 91/92 Z28 I'd like to know how high the front spoiler is off the ground at the front tip. How far is it from the front to the start of the wheel well? Same thing for the back end. How far off the ground is it? How far is it from the rear end to the start of the wheel well.
I was thinking this morning when I was leaving work, I can back straight out of my driveway but its close, thirdgens are a bit lower if memory serves me right so I could probably angle it. I need these measurements to compare with my TA. Thanks for the help guys
Old Nov 23, 2005 | 05:56 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Get a new drive way layed down with less of a slope or move.
Old Nov 23, 2005 | 06:16 AM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
If you check out autotrader.com and click on compare cars you can get the dimensions of most cars. Might help you out a bit.
Old Nov 23, 2005 | 07:57 AM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
I dont need dimensions of the vehicles, I just need the height of the front and rear bumpers at the ends of the cars, it'd be nice if someone could get me the distance from the front of the bumper to the start of the wheel well.
Who in their right mind would redo their entire driveway? If I can back my 4th gen straight out with no problems albiet its close, then you'd think a 3rd gen could be angled in maybe go straight in.
Edit: I'm not moving, we just bought the house in July, and I'm not moving till its paid for in 7 or 8 years.
Old Nov 23, 2005 | 08:09 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
ITs called Sa-Crete.
Comes in bags.
Mix with water.
Bingo, instant less slope in about 12 hrs :-)
later
Jeremy
Old Nov 23, 2005 | 08:16 AM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Is it really that hard for someone to measure two things for me?
Old Nov 23, 2005 | 08:56 AM
3.8TransAM's Avatar
I dont have one or I would :-) Only got me 3 birdies.
But any driveway with that big of a hump needs to go or Sacrete it up to lessen the hit.
It is the curb that is that bad or is the angle of the actual riveway that bad?
Remember they get lower as they age too.
later
Jeremy
Old Nov 23, 2005 | 09:44 AM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
later
Jeremy
The angle of the driveway actually isn't that bad, my buddy gets his STi in it without a problem. My exhaust is a bit lower than normal on my TA and is about an inch or so from scraping when I back straight up. Teh stock exhaust would have no such problems.
Old Nov 23, 2005 | 11:30 AM
Vader's Avatar
I've got at least 1¼" of ground clearance, which is plenty for me:
On the other hand, I need the 4" high ramps just to get a low profile floor jack under it.
Our cars have a 44" front overhang (from the axle centerline) and are designed to have 4-5/8" ground clearance. Old springs and modifications can change that, however.
Old Nov 23, 2005 | 12:03 PM
robsgta's Avatar
This is too funny..
Its no mystery why no one responded to your question before.
If your cars driveway is that darn steep looks like you will be parking it in the street.
Not every single 90 to 92 Camaro Z 28 are going to share the exact same ride height at the front or rear ground effect the air dam in front of the radiator hangs down further.
Different size wheels or tires will change ride height . Have you ever set a brand new tire next to a wore out one the same brand and size.
How are you going to mock up or apply these measurements to your driveway. I might have to air up all 4 of my flat tires on my Z to get your measurements this I have to see !!
Old Nov 23, 2005 | 12:46 PM
Vader's Avatar
Just take some measurements of the approach lenghts and angles of the driveway, and paste them into an imported CAD image of the vehicle.
Old Nov 23, 2005 | 12:58 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
That would work I dont know why this is so hard or even why I'm getting so much ****, all I want is too measurements, I already said the driveway isn't that steep. If my car were stock it would have no issues at all. It's not stock and thats why I only have about an inch worth of clearance.
Old Nov 23, 2005 | 12:59 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
This is too funny..
thanks for the response
Old Nov 23, 2005 | 01:05 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
15 inches of clearance would be EASY to get in the driveway. 1 1/4 you mean 1 and one quarter feet? that seems a bit on the high side.
I dont really think I'd have a problem getting one into or out of the driveway, I just was trying to make sure. I probably wont find a car locally since I live in a small town, I'd just had to drive to OKC or DFW get a car and then find out I can't get it in the driveway. Like I said my buddies STi has no issues at all and that thing is pretty damn low, just better safe then sorry when I bring home a car and scrape the **** ouf of the front spoiler
Old Nov 23, 2005 | 04:38 PM
Vader's Avatar
No. Like it says, 1¼ inches to the air dam/chin spoiler. I've got the same on the side air skirts.
Old Nov 24, 2005 | 04:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
well my 89 roc has a prokit on it, but the rear is about stock height. the front is lowered about 1.5inches
mine is currently being stored in my garage and the rear floor is slightly sloped but i took a level to get an idea of even ground. so my measurements for the rear should be close
ground to chin spoiler is 6inches off the ground
ground to airdam deflector is 2.75 inches
front of chin spoiler to wheel well is about 24 inches.
just in front of the front tire to the ground is about 6 inches as well.
just behind rear tire to ground is 6 inches for my car
rear bumber to just behind rear tire wheel well is about 26inches
i got flowmaster exhaust and the tips are about 11 inches off the ground. the bumper is another 5 inches up so a total of 16 inch off the ground.
hope that helps
Old Nov 24, 2005 | 10:06 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
hope that helps
Awesome, that fixes me up quite nicely. I'll double check my stuff tomorrow but I think I will have plenty of clearance
Old Nov 25, 2005 | 06:32 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Our driveway has a steep angle to it, one of my TA's is pretty low with a pro kit with 1/2 coil cut off the front. I just use two wooden planks laid paralell to the road to lessen the hit.
Old Nov 26, 2005 | 10:50 AM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
I was goinmg to go measure mine. Put on my shoes and walked back to the shop... started measuring. Then I remembered...
my car doesn't have a ****ing motor in it.
That won't help.
Sorry.
Old Nov 26, 2005 | 12:02 PM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
That won't help.
Sorry.
lol no problem man, between here and cz28 I think I got the info I need looks like I shouldn't have any problems
ex-x-fire
Jan 12, 2024 01:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
