Dyno Tuning
Old Dec 8, 2005 | 04:51 PM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
Dyno Tuning
Ive been wondering how much power my LB9 could gain from a professional dyno tune. Is it worth the $250-$300? Or am I better off spending $600 on nitrous, and adding a solid 100HP/150TQ
Ive heard some poeple say it will add a few horsepower, others say it can make all the difference.
Some actual testimonies would help me out
Old Dec 8, 2005 | 06:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
well chip tuning on a stock L98 vette with exhaust picked up 30hp
so yeah i bet u have some to gain if you got some minor bolt ons/exhaust
Old Dec 8, 2005 | 06:30 PM
Shake Zula's Avatar
Cat-back and AFPR
Old Dec 8, 2005 | 07:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah u probly could see some good gains.. who knows
whats ur definition of a good gain? 10hp? 30HP? i can see maybe an additional 15 hp with tune easy..
however is that worth the 300bucks? i'd buy some more bolt ons for now or nitrous
Old Dec 8, 2005 | 08:37 PM
Shake Zula's Avatar
Ive been thinking 15-25HP for a stock LB9. Ive heard it can make upwords of 100HP on modified engines.
Probably better off with the nitrous kit I guess.
Old Dec 8, 2005 | 08:44 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Originally posted by Shake Zula
Iv'e heard it can make upwords of 100HP on modified engines.
Damn.
Old Dec 8, 2005 | 11:57 PM
JPrevost's Avatar
Car: 91 Red Sled
COMPLETELY stock? Dyno tune isn't worth it. Add some goodies like headers and CAI and you might want to get it done before the nitrous. Spraying on an untuned SD car that's already near the lean AFR limit at WOT can be really bad with nitrous. Is the 90 MAF or SD?
Get the dyno tune or better yet, get your own burner/adaptor/flash chip for like $125 and make your own track tune . What's more impressive, a car that makes hp on a dyno or one that shows gains at the track?
You might also look into replacing the fuel pump with something that will be able to keep up with the nitrous. A walbro 255lph should be a no brainer...
Old Dec 9, 2005 | 08:29 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Do you want more power all around or just once in a while for racing. That should answer your question as to whether you should get a tune or nitrous.
Old Dec 9, 2005 | 01:54 PM
Shake Zula's Avatar
Its my daily driver, so I only need the power on weekends. Which is why I consider using nitrous. But, knowing your car is in good tune is also something nice to know. If dyno tuning made like 50HP on a stock engine, I'd do it.
Ill probably ending up selling it by the end of summer anyway, so if I buy nitrous I can at least switch that over to my next car.
Old Dec 9, 2005 | 01:58 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
whats more important is dyno tuning your nitrous shot
that will make sure you air fuel is right and no risk to blowin up. and u can optimize your tune for the nitrous
LT1Formula
Oct 8, 2015 08:34 PM
