how much hp in this combo?
Old Dec 10, 2005 | 06:31 PM
85rocker's Avatar
has anyone done this setup before?
'90 IROC L98 with
- udrive pullies
- 1 5/8 headers to dual cat and hi-flow cat back
- 210/220 .510/.510 cam
- accel base
- accel runners
- ported matching plenum
- k&ns
- afpr
Everything else if factory. Does anyone have an idea what HP this setup makes? How much tq?
thx
Old Dec 10, 2005 | 06:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
with a good tune as it should need one, i would say 320hp or close to that on motor. speed density is abit finicky when it comes to mods like that. especially a cam
that cam is the compucam 210/220 isnt it? looks familar. that should run good in TPI and require minimal tunning. you could get by by just running AFPR for the most part, but i'm not as sure on speed density. i know MAF could get by
the base and runners swap in that car should open things up alot.. along with the headers
my car with just headers/exhaust and 2800stall/3.27 gears has trapped 100.8mph
that combo should be well on its way to 105mph when tunned right
Old Dec 10, 2005 | 09:55 PM
85rocker's Avatar
yes it is a compucam its about as far as I could go with the speed density without a mandatory tune.
I have been checking into head work as well. I figured I'd send the 083s into the shop for some porting, bowl work, bigger valves and three angle grind. I am hoping for 325 at the crank.
Next question is has anyone seen any good results from working over the factory heads?
thx
Old Dec 11, 2005 | 05:25 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
there was a thread on here with someone extensively working over a set of heads....
it gave a break down of what was done, from mild bowl blending to final stage of full out hogging the heads and larger valves
if you can do the work yourself and dont mind spending the time to do so.. you can get some very impressive flow numbers and make some good power
Old Dec 11, 2005 | 08:02 PM
Shagwell's Avatar
Car: projects.......
another thing, there's A LOT to be had BEFORE needing larger valves. Yes, 083's can make good power. Dollar for dollar, if you can't do atleast some(most) of the porting yourself, you'd probably be better off just buying some good aftermarket heads...
- and yes, that combo sounds pretty good for 325 ish, flywheel.
Old Dec 12, 2005 | 05:14 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I got 251 rwhp and 318 TQ with the stuff in my sig ...untunned . The ZZ4 cam is kinda close .... 208/221
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
