Afpr
Old Dec 10, 2005 | 07:57 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Afpr
Are these crap or am I better off getting the holley version?
http://cgi.ebay.com/ebaymotors/1985-...21026408QQrdZ1
Old Dec 10, 2005 | 11:07 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I cant tell how this one works, it appears that the adjustment is done by a screw and locking nut. What is the round piece? (the gasket)
Anyway, I have a Holley and adjusting the fuel pressure is very easy, a simple turn of a large wheel on top of the AFPR,,, and this wheel is serated.
Old Dec 11, 2005 | 08:30 PM
Shagwell's Avatar
Car: projects.......
the round peice is what sets between the spring and the adjuster screw. By tightening the screw, you push on the spring, there fore increasing fuel pressure. - Yes it appears that you would adjust the screw, then lock it w/ the nut. - looks to be a decent unit. Not at all different than my TPIS unit...hummm.. good thing I didn't have to pay for mine....I have great friends...
Old Dec 11, 2005 | 10:02 PM
antman985's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 5.7L V-8 (Ram-Air)
Transmission: TH700R4 with stock 2.77
Hey i know i didnt start this topic but i do have a question..... is AFPR good to put on a STOCK tpi? if so what would be a good psi to set it at??
Old Dec 11, 2005 | 10:05 PM
5.7tpiroc's Avatar
Car: 89 Iroc
Engine: 5.7tpi
Axle/Gears: 9 bolt posi w/ 2.77s
i have one on mine and no it doesnt hurt to have an aftermarket one, and there is really no set pressure to set it at, put it on a dyno, adjust it and go, repeat as needed until you find out which one works the best.
Old Dec 12, 2005 | 07:01 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
As I understand it 48PSI is a decent pressure.
Old Dec 16, 2005 | 10:18 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
48psi with the vaccum off is a decent setting, anything over tends to foul plugs. Make sure you set it with the vaccum from the modulator off the unit. Turning up your fuel pressure will make a VERY noticable difference in your cars midrange power most of the time.
Old Dec 16, 2005 | 09:30 PM
shaggy56's Avatar
Car: 71 Nova
I hope I got the right one.
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
Old Jan 7, 2006 | 12:12 AM
antman985's Avatar
What do you mean by setting it with the vacuum off? How is this done?
Old Jan 7, 2006 | 02:43 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
You pull the vacum line off the regulator, then set the pressure, then reconnect the line. This line goes from the regulator to the plenum.
Old Jan 7, 2006 | 11:28 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
dude if you are trying to save 30 bucks dont. I have first hand experience with throwing that e-bay part in the garbage.
Old Jan 8, 2006 | 12:42 AM
shaggy56's Avatar
Car: 71 Nova
I ended up getting the holley one. I did save $30 if you look at the second link I posted. In fact its already installed. The thing was brand new and never installed either.
Old Jan 8, 2006 | 01:26 AM
antman985's Avatar
how did it work? make any noticable differences? im looking to get one installed on my car, but my car is stock, so im not sure if it will make any noticable gains. let me know! thanks!
Old Jan 8, 2006 | 07:24 AM
jamon8's Avatar
Engine: 350 tpi
there is a tech info on this web site about the gains in a stock motor something to do with better fuel atommization.
Shaggy I am glad to hear that you got the holley. You made the right choice
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
