I Need Interpretation Help...
Old Dec 12, 2005 | 07:20 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I have an AutoXray 4000, and I hooked it up to my ALDL to get a feel for what's happening as I drive. My observations were all in closed loop at both highway speed (70 mph) and normal city driving (45 mph). I do want to state that I know I'm not actually "datalogging" or doing anything of any real scientific value, I just need a couple opinions as to what I saw and may need to do. I DO want the car to be in top-tune before I bolt on new cats and intake components.
First thing I noticed was my O2 Sensor did not give me a steady reading, It fluctuated to the point of unintelligible output the whole time. I think I need to be between 450 and 500 milivolts but couldn't get a fix. Does this tell me I may have a faulty O2?
The Block Learn was w/in 128 +/- 6 and the INT was the same, this is good right?
My biggest question was the Spark Advance. I have yet to set the timing (in the next couple weeks, 6*- 8* base, right?) on this engine. Just found out the guy who put this engine in din't set the timing. SO, if you'll notice my setup in my sig.....my reading showed I had 39.5* full advance at both city & highway speeds. That seems a bit high. At idle, the reading was in the mid 20*'s, that too seems a bit high unless that measurement on the AX doesn't account for base timing. I only had 11 knock counts and the most retard I saw was 1*. Is my rig way out of wack?
Any help here would be appreciated, cause I'm a little lost (obviously)
Thanks...
Eric
edit: oops, I meant for this to go on the Gen Engine board, I'm so used to reading the TPI board...sorry mods.
Old Dec 12, 2005 | 09:07 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Everything you state sounds perfectly normal.
Good to ask questions though.
Old Dec 17, 2005 | 03:55 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Follow Up Question
I got a timing gun today and I'm gonna time this puppy, eventually. There are a couple sets of instruction on where the positive and negative clamps go; how do you guys SAFELY hook them up? I got the inductive thing on #1 wire.
Also, I saw I have a chalk mark already on my balancer. It is sitting on 0 right now, does the engine stop on #1 TDC every time it shuts down or is this a fluke? Does this mean I actually have ZERO degrees base? And why did my AutoXray tell me I was running 39.9 degrees spark advance? If I set base to b/t 6-8, won't this create a bad timing advance? (like 45*-47*)
I don't know if it means anything or not, but my dis cap/#1 terminal is just left (looking at it from the nose of the car) of center..is this of any value to me?
Dazed And Confused..A Lil....
Eric
Zane Story
Oct 8, 2015 12:40 PM
R13_Braz
Sep 18, 2015 05:00 PM
Kj Rockz
Jan 6, 2002 06:00 AM
Locry
Apr 29, 2001 12:09 PM
98_1LE
Mar 1, 2001 12:44 AM
