Trickflow or Edelbrock Heads
Old Jan 16, 2006 | 04:01 PM
  #51
Shagwell's Avatar
Car: projects.......
I'm running the thick(1266) 1206 felpro intake gaskets. I'm also running the Victor .025 head gaskets. I had to go to the thick gaskets because my intake would bottom on the block before it fully tightened on the heads w/ the thin head gaskets. You'll have to trim a litte on them for Toplines. The ports are tall and slender, unlike any felpro gasket I found. Topline actually reccomends thier own gaskets, but to late at the time. The felpro's worked good, and the extra width was equal to my Team G intake so...works out good. - I guess I should now refer to Toplines as RHS...
Old Jan 17, 2006 | 01:21 AM
  #52
83 Crossfire TA's Avatar
Originally posted by madmax
When vacuum is applied to the EGR, at least on a TPI, the valve opens and if you do that at idle with no other changes the car will shut off from the massive vacuum leak you just created. If there's no crossover, no free air, no leak, no die. Non functional.
yea, or you can just pull up on the diaphragm with your fingers.
That’s not the point, I know how to test for a working EGR, I’m wondering how they test for it… I know that here in MD they used to have a visual inspection for it, and my brother used to take, through the egr valve on the manifold and then take it off once it was checked off, it just had to be there…
Old Jan 17, 2006 | 10:12 AM
  #53
Guest
Guest
Posts: n/a
Exactly the method you mentioned. I've never had someone test the solenoid, but have had them check vacuum and electronic parts in the past so I wouldnt put it past them to check if they felt the urge to do so for some reason.
Old Jan 17, 2006 | 05:02 PM
  #54
Shagwell's Avatar
so couldn't you just drill a small hole in the egr passage allowing for outside air on the input side of the egr? then if the egr was pulled opened, vac leak and stall... then just unhook(and plug) the vac line when driving it.
Old Jan 17, 2006 | 06:50 PM
  #55
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Why go through with all that. If smogging is an issue, leave it on and make the best hp an e.t. with it.
Old Jan 18, 2006 | 01:46 AM
  #56
introducing inneficiencies never results in the best hp. OTOH, it shouldn't really effect your ET at all (shouldn't be open at WOT) unless you don't give it time to cool down (running EGR does make the manifold hotter)
Old Jan 18, 2006 | 06:59 PM
  #57
Shagwell's Avatar
the reason I thought of the whole hole drilling thing was to enable someone to run a non-egr head. - I don't have emissions so nah nah na nah nah
Old Jan 18, 2006 | 07:01 PM
  #58
Shagwell's Avatar
as for the heat, i now remember yet another reason we run methanol on the race car. Roll into the beams @ 200, blast, no fans, no pump, pull onto the return road w/ 1/4 inch of ice on the intake(should say used-to, f/c chassis altered)
Old Jan 18, 2006 | 07:34 PM
  #59
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
they are the same price. That price is for each edelbrock, or pair trickflow. 1k either way.
z28guy134
Sep 1, 2015 11:50 PM
italiano67
Aug 31, 2015 06:04 PM
earlpote
Aug 28, 2015 10:42 AM
86IROC112
Aug 17, 2015 02:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
