Intermittent Code 22
Old Dec 31, 2005 | 03:38 PM
flexyj's Avatar
Car: 1990 YJ
Engine: 406 TPI
Transmission: TH350
Okay, I followed the manual exactly. Got a code 22, reset the code started it got the code again. Reset the code, jumpered the 5v reference wire to the to the signal wire, got code 21. Reset the code, read the voltage from the TPS. It was low, at 0.29V. Adjusted the voltage to 0.54V. Also checked the reference voltage just to make sure and it was at 5.0V. Buttoned everything up went and drove it for a while, 10 minutes into the drive got code 22 again. Checked the voltage and it was 0.24V. I can't imagine that the sensor could possibly move, I know it was tight. But just to make sure, I'm going to adjust it back to 0.54V again and mark the sensors position on the TB. Also, when I adjusted the sensor the first time I checked to see where it was at at WOT and it was only at 3.1V. Isn't it supposed to be above 4V? Any ideas what I might want to try next?
Old Dec 31, 2005 | 04:32 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Sounds like you need a new TPS. You should see more than 3.1V at WOT. I once had a tps drive lever slip on it's shaft.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Reid Fleming
Oct 10, 2015 09:56 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
