MAF TPI connector - ???
Old Jan 2, 2006 | 04:26 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
can someone please tell me what this goes to? I am doing carb to tpi swap and still haven't figured out the purpose of this connector yet, thanks
now a close up
The manual only refers to it as an engine connector. It is in the ECM wiring harness right there near ESC.
Tony
Old Jan 2, 2006 | 07:28 PM
Car: 1986 Iroc-Z
bump - anyone
Old Jan 2, 2006 | 08:05 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
There are two connectors that go to the distributor,,, have you identified both of those connectors?
BTW, I do have a connector that goes to nothing on my '87 TPI, and it is located exactly where you have that connect, behind the engine (mostly on the drivers side) and its a two prong connector.
Old Jan 3, 2006 | 06:07 AM
Car: 1986 Iroc-Z
Doc - I have found both small plug in connectors for the dist, battery and tach. I also have connected the 4 plug to the dist. That is great to hear you have an empty plug, I believe this to be an 87 harness as well, THANKS!
Tony
Old Jan 3, 2006 | 10:33 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I believe it plugs into the chassis harness that comes out of the driver side firewall.
Old Jan 3, 2006 | 11:24 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Man I just dont recognize that plug.... Not anything related to TPI anyway, must be something for the chassis harness.
Old Jan 3, 2006 | 11:28 AM
Car: 1986 Iroc-Z
OK, we'll see what doesn't work tomorrow when I go to start it. Everything else has a home except that. I did not get the drivers side TPI harness becuase I was told by all that I did not need it, just the ECM and its harness were required to do the swap. I will look through the service manual on the drivers side harness and see if it is on there also and what it leads to. Thanks guys
Old Jan 4, 2006 | 05:58 AM
Car: 1986 Iroc-Z
I found the location of this connector. It has 2 wires that lead to it from the drivers side harness. They come from the oil pressure switch and ECM B8. They connect to the drivers side harness and go to the gauges.
89GTAOz
May 16, 2020 09:31 AM
NBrehm
Aug 25, 2015 11:49 PM
perZ
Aug 15, 2015 01:17 PM
Sanjay
Aug 12, 2015 03:41 PM
