another setting minimum air question..
Old Jan 6, 2006 | 05:11 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Well i followed the procedure and when i went to unplug the connector to the IAC i noticed it was making quite some noise. Its really loud and whinny and even after waiting 5 mins it continued to make the noise...is this normal? I assumed that after 30 seconds when it reaches closed position...that it would stop making the noise...
Old Jan 7, 2006 | 01:38 AM
Vader's Avatar
The ECM will continue to send the phased pulses to the IAC motor as long as the ignition is on and the ALDL is jumpered. The reason to wait 20 seconds is to make sure the IAC motor has stepped fully closed. In reality, a new (or cleaned and lubricated) IAC should close in just a few seconds.
Your observation is completely normal.
Old Jan 7, 2006 | 09:56 AM
Car: 1991 Z28
Engine: SBC
ok thanks, just making sure i didnt blow money on a new one
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
