Will this ZZ bottom end be a direct replacement bottome end for my L98?
Old Jan 7, 2006 | 09:17 PM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
I searched on GM parts direct and found the bottom end of a ZZ type motor. It says
"Provisions for a steel roller camshaft and one piece rear main seal are state of the art"
So does that mean that my L98 cam or cam I would get for a L98 fit in this block with no issues? If so then wouldn't you be able to buy this block, put stock or aftermarket heads for a L98 and TPI intake on it and be ready to drive?
The block im looking at is at http://www.gmpartsdirect.com/results.cfm
and the part number is
12561723
Old Jan 7, 2006 | 09:56 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Yes that will work with your cam and heads
Old Jan 7, 2006 | 10:04 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
great, thanks!
Old Jan 7, 2006 | 10:06 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
you know, for this engine being just over $2000 and coming with this kind of equipment
ZZ PARTIAL ENGINE
With its four bolt main block, and forged steel crankshaft, the ZZ partial engine is a proven winner. Its forged powdered metal connecting rods, steel crank, and light flat top hypereutectic pistons ensure high rpm performance. Provisions for a steel roller camshaft and one piece rear main seal are state of the art.
I wonder why I haven't heard of this before. Seems to me to be a great deal!
Old Jan 7, 2006 | 10:27 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
For 2000 I could build a forged 383 short block
Old Jan 7, 2006 | 10:55 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
I guess to each his own, i know of too many disapointing 383's to want to build my own, this engine will be perfact for what I want to do, to get what I want, I belive is worth $2000
Old Jan 8, 2006 | 12:24 AM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
Well it is worth that's a good price and its what you want.
Old Jan 8, 2006 | 08:56 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think you could assemble the parts and machine a block that can withstand much more that it, for less than 2100.00 plus shipping.
Consider you don't get the timing chain and cover, oil pan, lifters,cam, etc...
Basically a block, crank, rods, rings,bearings and pistons.
If I were going that route, I might be thinking to compare the cost of an aftermarket block and build accordingly.
Old Jan 9, 2006 | 07:37 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
The ZZ bottom end is a good way to start an engine. If you have a good roller block you might consider rebuiding it if you think you could. Engine building can be a daunting task. After machine work and paying to have the shortblock assembled you will probably spend about what you would have in that ZZ short block. If you dont have a roller block that is good enough to take to the machine shop you should think about looking into a crate motor that has the fast burn heads. I think its called the ZZ383 it comes with fast burn heads (same heads used on the ZZ430) these heads take either a vortec bolt pattern or an old style bolt pattern, and flow very well.
Old Jan 13, 2006 | 02:21 AM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
Thanks, ill look at the set up with the fast burn heads. How would I find out and compare between the fast burn and say AFR heads?
Old Jan 13, 2006 | 11:00 AM
jmiller's Avatar
Car: 87 IROC - 67 Camaro
Engine: 383 TPI - ZZ4 TPI
Transmission: 700R4 in both cars
Axle/Gears: 3.27 - 3.36 posi in both cars
If it's the same block as the ZZ4, you probably will drop the compression when using the L98 heads. The aluminum heads on a ZZ4 are app. 58 cc combustion chambers, which gives the motor 10.0 to 1 compression. I don't know how big the L98 combustion chambers are but I would imagine them being larger. I've never run across heads with less than 60cc chambers.
Old Jan 13, 2006 | 12:22 PM
dbtk2's Avatar
Car: 1986 Trans Am
Engine: Carb'd 305
Axle/Gears: 10 bolt, 3:42's
Stock LG4 heads are 58cc IIRC......
Old Jan 16, 2006 | 03:23 PM
Damon's Avatar
A stock L-98 bottom end has dished pistons and has about 9.3:1 compression with stock cast iron (Camaro/Firebird) L-98 64cc heads and factory head gaskets.
A ZZ-4 shortblock has flattop pistons and compression with 64cc heads would be up in the range of 9.8:1 if used with GMPP .028" thick head gaskets. Using thicker .039" Fel Pro head gaskets would drop it down to around 9.5:1
Old Jan 16, 2006 | 07:52 PM
jmiller's Avatar
Yea, I new L98 heads had larger chambers. I think you're pretty close with your guess.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Amillionoh7
Aug 7, 2015 01:24 PM
