what ive lurned when installing summit tpi cam
Old Jan 13, 2006 | 06:33 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
***KINDA LONG*******TY SPELLING(its how i roll)***
the things ive lurned when installing summits tpi cam:
well ive got about 1:30 left of work befor i can start her up, what i have for a car see sig. (no turbo yet)
1: stock valve springs are week, and easly removed with socket/hammer and spark plug removed with air hose hook up and set to 40 psi
2: the motor has 130XXX on it and all the valve seals but 2 were ****, im talking all the seal part that hits the valve gone
3: carbon dioxside posioning sucks when you pass out and wake up, upchuck and then pass out again
4: a duble rollor chain and sprocket will fit under the stock timing housing
5: you dont have to take off the oil pan to put the timming covor back on if you take about 1/2 an inch form the botom that gos in the pan
6: useing rtv gasket maker for gaskets on the lower runners (were they attach to the intake mani) will not make the intake plunom fit right on top of the runners ( any one have a napa part # for the gaskets??????)
now for the ?
i blocked off the egr and took out the thing that controls the vac to it and the carcole canister ( witch was also removed) this will set codes i know but the car will still run??? and i got a low temp fan switch were is the one its going to replace?
Old Jan 13, 2006 | 06:43 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: what ive lurned when installing summit tpi cam
Originally posted by high c
now for the ?
Yes it will run, but you will need to put a filter on the gas tank vent line. Do not plug it off.
The fan switch is usually on the driver-side head but check both of them.
Old Jan 13, 2006 | 06:45 PM
high c's Avatar
Car: 86 iroc
thanks man
Old Jan 13, 2006 | 07:52 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Huh, CO2 or CO? Did you pass out for a long duration? Was it at work? Sounds like Comp.
Old Jan 13, 2006 | 10:09 PM
high c's Avatar
Car: 86 iroc
CO, i was out for around 15-20 min, no this was at home
Old Jan 13, 2006 | 10:43 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
So how does it run with this cam? Thats on my back shelf wants for my '86. Havent heard a bad thing from somebody yet about this cam.
Old Jan 14, 2006 | 07:13 PM
high c's Avatar
Car: 86 iroc
i just finished it tonight around 630 and took it for a spin and alls i have to say is wow its like a totaly diff type of animal for what need to be done to install it and what ive lurned from it i would give it a out of 5
Old Jan 14, 2006 | 07:21 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Just dynoed my '86 today. It put down a very anemic 141hp/227tq. Thats only with K&N filters and no cat. The TQ comes in early but the HP drops off after 4500 rpms. Ive got to get this cam!!
Old Jan 14, 2006 | 07:39 PM
high c's Avatar
Car: 86 iroc
tommarow, if it dosent snow or theres not to much rain ill go out and get some vid of it on the road, what ive got done is:
305 tpi:
cam, lifters, springs
smog pump delt
170 termo
open eht were the cat use to be
airfoil
52 k volt out put coil
accel 300+ raceing ign
EGR delt
carcol canister delt
TB coolent bypass
built trans
2000 stall converter
NGK-r plugs gaped at 50 thouthes
Old Jan 14, 2006 | 07:47 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Sweet, Get some vids of the exhaust if you would. Wouldnt mind hearing the cam again.
Old Jan 15, 2006 | 09:24 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
What kinda lift / duration and LSA is in this summit TPI cam???
How far does it pull now? RPM??
Old Jan 16, 2006 | 06:25 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Well my patience has paid off. Summit had had a few of these cams on Ebay and I was tracking it for a while. The price just dropped $20 !! So I got one on the way .
Old Jan 16, 2006 | 06:27 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Advertised Exhaust Duration 278
Advertised Intake Duration 268
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.442
Intake Valve Lift with Factory Rocker Arm Ratio 0.420
Lobe Separation (degrees) 112
Basic Operating RPM Range Idle-5,500
Hope that helps.
Old Jan 16, 2006 | 12:31 PM
high c's Avatar
Car: 86 iroc
sorry for the weight, but we have 4 inches of snow in maine now, but its sunny so im hoping that most of the **** will be off the road by tommarow some time and for the power band, i shift at 5200 but it still pulls at 5200
Old Jan 16, 2006 | 02:41 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
How bout duration @ .050 int/exh?
Old Jan 16, 2006 | 04:11 PM
high c's Avatar
Car: 86 iroc
204 214
Old Jan 16, 2006 | 07:27 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Thats a relatively small cam, but i bet it makes a ton of torque and low end power.
Old Jan 16, 2006 | 08:14 PM
high c's Avatar
Car: 86 iroc
i have a small motor and its a HUGE step up from what use 86 guys hade to start with
Old Jan 16, 2006 | 10:17 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
anyone out there run the Comp Cams 210/220 .500/.510 lift???any results, even if it's seat of the pants evaluation........ Power band and max rpm?
Old Jan 21, 2006 | 04:21 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
you mean the .503 and .510 with 1.5 rockers? i have 1.6 pro comp magnums with that cam installed in my 355. I have yet to start it up as i switched from carbed setup to FI, so i had to convert everything. just tested my -6an fuel line setup again after fixing any leaks and so far there are none I also installed an lt1 intake with accel 58mm tb, world products sportsman 2 heads, hooker 2210 lt headers. i need to make the cold air intake, finish up the wiring, and break it in. hope to break in in the next couple weeks. i will post how it feels
i talked to someone that installed this cam in a stock 350 tpi car and they said it was a big improvment over stock, but the stock tourqe converter was not high enough on the stall. Comp recomends a 2200 rpm stall i belive with this cam. just food for thought.
by the way, that is a huge cam for a 305. guys who have put a stock l98 cam in a 305 have great results, you should have spectacular.
Old Jan 21, 2006 | 04:41 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
This is a great cam to do an in-car cam swap into a mild 305 with, you'll have no worries about valve train problems, no head mods required, etc. I'm sure you could step up the cam size wise even more and if you're doing a more comprehensive rebuild or some head work or whatever you probably would be well advised to go bigger, but this a great cam to just throw in w/ no worries for a pretty significant gain over stock IMO.
It idles fairly aggressively in my old IROC, but it could probably use some custom tuning and cut down on that some...
Swapping this cam in was my first major engine work I'd done, learned a lot doing it and nothing was a big problem or obstacle. Hardest part if I recall correctly was actually trying to get the timing chain cover back on without loosening the oil pan or tearing up the gasket there, lol.
Frozer!!!
Jan 19, 2024 04:55 PM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
camaro71633
Sep 1, 2015 10:24 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
