answer please
Old Jan 16, 2006 | 03:34 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
answer please
Can I put an in tank pump and pick-up unit for TPI from a 1985 f-body into my 1984 f-body which was originally carburated?
According to the 82-92 CD from MM the part numbers for the tank are the same.
can someone advise
thx
Jeff
Old Jan 16, 2006 | 03:42 PM
Shagwell's Avatar
Car: projects.......
yep...
Old Jan 16, 2006 | 03:53 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Just gotta regulate the pressure down, and use a return line-if you're using
a carburetor, assuming I read your post correctly and you are using a carb.
Old Jan 16, 2006 | 05:20 PM
jjlabinski's Avatar
Engine: shinny 350
No. . .converting my 84 to TPI. Want to put TPI pump set up in my 84 tank.
Old Jan 16, 2006 | 06:05 PM
'Shifter's Avatar
Car: 87 Z-28
You should be golden!
grngryoutmyway
Oct 18, 2016 05:48 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
